Old 04-25-2011, 04:23 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by pimp my yaris View Post
Oh ya. On my first start up the car would barely run. My wide band was pegged at 10:1. Most of my new fuel map is pulling duty cycle back with negative percentages. I am running positive percentages in high boost. The FIC actually zeros out (no intervention) at about 2 psi of boost. At idle its negative 27%
I think you must precise more this post when saying " I am running positive percentages in high boost". How much positive and how much boost?
Running low AFRs are not very good to the engine. Excess fuel tend to mix with engine oil and you can see it dirty after 2 runs already. Running dirty oil mixed with fuel tend to make flash marks on the cylinder bores due too low lubrication to the piston rings. Also turbo bearings tend to fail earlier because of this. I am mentioning this from experience so prevent running the engine like this.
Do you have an upgraded fuel pressure regulator? With the regulator you can reduce fuel pressure and equalizing fuel ratios (although I don't know how the stock ecu reacts having it installed)
Parmas is offline   Reply With Quote
Old 04-25-2011, 09:01 PM   #2
cdydjded
Drives: Yaris LB Turbo
Our cars use a return-less fuel system, it does not have an accessible FPR. The FPR is inside the fuel tank.
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 03:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
