#1 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Running low AFRs are not very good to the engine. Excess fuel tend to mix with engine oil and you can see it dirty after 2 runs already. Running dirty oil mixed with fuel tend to make flash marks on the cylinder bores due too low lubrication to the piston rings. Also turbo bearings tend to fail earlier because of this. I am mentioning this from experience so prevent running the engine like this. Do you have an upgraded fuel pressure regulator? With the regulator you can reduce fuel pressure and equalizing fuel ratios (although I don't know how the stock ecu reacts having it installed) |
#2 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 03:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 03:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 02:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 03:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 03:10 PM |
