Old 07-01-2011, 03:44 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
Originally Posted by Flipper_1938 View Post
I think I am finally over my whiplash enough to finally get lowering springs. I have held off do to the firmer spring rate.
Which swaybar do you guys recommend for a sedan? the 19mm or 23mm? Has anybody here actually tried both?
Adding a 19mm bar will make a world of improvement for both handling and stabiltiy.
That said, I'm now considering the step up to a 23mm bar as understeer is still prevalent. And when the weight of the Blitz S/C is added up front the power-on understeer can only increase. Time will tell.
Old 07-01-2011, 04:14 PM   #2
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
With your current set-up, in the rain or snow, do you get understeer of oversteer?
Potential crappy handling in bad weather is the only thing making me consider the 19mm one.
Old 07-01-2011, 07:29 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
I've NEVER experienced oversteer whether wet, dry, frozen or deep with white.
After years with RWD cars I crave some four wheel driftability and balance is required to achieve that.
Old 07-01-2011, 07:56 PM   #4
Flipper_1938
That's nice to know.
The rusty truck in my avitar was detuned last year due to crazy oversteer. 400+ horsepower and a very tight posi rear axle meant that rear end was always trying to come around. It was fun when you wanted it, but it was a pain to drive in the rain. It is probably 325 horsepower now, but a lot nicer to drive.
Since the Yaris is my everyday transportation, I want to stay well away from the edge.
Swaybar vs. lowering springs eht13 General Yaris / Vitz Discussion 52 10-04-2010 07:59 PM
Front swaybar deconnection....anyone tried it dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 07-28-2007 10:20 PM
