Old 09-20-2011, 11:03 PM   #1
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Originally Posted by Bluevitz-rs View Post
I borrowed the puller set from my local dealer because I had the option to. The puller is specifically designed for disassembling the transmission. Only thing I needed to fab up was a trio of studs. I'll take a picture. You can use any pullers you'd like, just make sure they're not going to chip the teeth on the gears.
I chipped the teeth on one of the gears on my old box trying to remove it. There is bugger all room under the gear to get the legs of the puller in there.
A bit of creative grinding on a puller might let you get under there easier without damaging the teeth.
PS, zip ties don't work
rob323 is offline   Reply With Quote
Old 10-11-2011, 07:59 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
So you used a standard bearing puller like this or a 3-jaw puller like this?
6 speed, conversion, gearbox, transmission
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
