![]() Drives: 2010 Yaris Sedan Join Date: Mar 2011
I recently started a new job as a courier. I drive about 10,000 miles a month. I'm getting my oil changed every two weeks. I want to make the switch to synthetic. I'm thinking of going with Amsoil SAE 0W-30 Signature Series. According to the manufacturer, I can go 25,000 miles on each oil change. Does anyone have any input on this? Anyone else travel high miles like me? If so, what do you use? When I make make the switch, should I do a flush? I have just a little over 50,000 miles on my 2010 Yaris.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
Amsoil is a perfectly fine choice. If it were me, I'd run out to 7 or 8 thousand miles and then pay for an oil analysis test. That's the only way you can be sure that the oil is holding up well in your particular application.
Another thing to consider is that Amsoil says the oil will hold up for 25,000 miles, but the oil filter they spec for the 1NZFE is only rated for 15,000 miles. |
#3 | |
#4 | |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
You can try 100% syn and see if it results in oil leakage. If not, go for it. I personally use Mobil 1 0w20 and change at 10K. I have almost 60K and never had any problems. AMSOIL is very expensive! You can usually buy Mobil 1 at Advance Auto on sale and get 5 quarts and an oil filter for around $25. After four or five of those, you have enough left overs for a free oil change.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
| LB M/T options | Howard2621 | New YARIS Purchase Forum | 1 | 09-22-2006 10:37 PM |
