Old 12-08-2012, 09:07 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Originally Posted by petyanca View Post
Driver or not, car allows for faster turns now, but tires become the weak link. I still have stock tires, they are a harder compound tires but ok for now. When they wear off if I put softer tires on would they do better in terms of peeling off flakes?
Sounds like you are "chunking" your tires. Basically overheating the tread and it comes off in chunks/flakes. This is why performance tires have less tread depth than all-seasons. End of the day, anything you do to reduce the chunking (tire pressure, neg. camber, better tires, etc) will make the car corner faster.... and wear tires faster! If you are worried about tire life, slow down.
Cheers.
Cory
PS: I figure if you don't put tires on your fun car no less than every two years, you aren't having enough fun. Then again, I use R-comps for street tires....
Old 12-09-2012, 12:08 AM   #2
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Back before I ever heard the term drifting (early 90's), I used to go through a bunch of tires on a hot rodded camaro z28.....from brand new to belts showing in about a month. I had lots of fun!
sway bar, tires
My Ultra Racing rear sway bar install CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 49 03-03-2011 02:08 AM
TRD Rear Sway Bar detroiter Items for Sale by private party 15 08-05-2009 01:01 AM
sway bar... Toyota dealers must be insane! RedRide General Yaris / Vitz Discussion 10 07-24-2009 03:39 AM
Sway bar and struts DOMAV Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-17-2009 02:26 AM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 08:07 AM
