Old 05-29-2013, 10:07 PM   #1
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
That is true. You may want to pop the fuel pipe connector that is by the brake booster to see if you actually have fuel pressure (that is the one that is a quick release and is shrouded by a grey plastic piece).
Thanks, that would be a perfect starting point to find the actual problem.
To be more precise, I should prime the pump with that connector off and see if I get any fuel delivery. Should I prepare for something messy :P??
maxthehax is offline   Reply With Quote
Old 05-29-2013, 10:26 PM   #2
kou
Drives: 08 lb
Yes it could be messy.
Old 05-29-2013, 11:13 PM   #3
I would start with simply disconnecting it. You should get a little spray as you do, so wrap it with a rag before pulling it apart. If you don't get a good pssssst, then you can simply turn the ignition to the ON position (you don't need to crank it) and the fuel pump will start running to maintain pressure, so you should then get a good flow of fuel (have a container ready to catch it).
Old 05-30-2013, 08:00 PM   #4
maxthehax
maxthehax's Avatar
Okai thanks for infos.
I did not try it yet. But, I did try to start the car after work today. It started and I SAW some fuel on my AF gauge, so fuel is delivered. Car was running on idle but with a lot of stumble, always looking to die/stall. Very lean A/F also.
While it was on idle, trying to keep running I could ear a ''push push push'' sound everytime the engine catch up. The push sound was very close to the intake manifold.
?? Is it possible that I have blown the intake manifold gasket? Would a intake manifold leak make the engine run very lean? also make it stall everytime I try to start it again. ??
Thanks guys for inputs.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 11:30 PM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 10:20 PM
