Old 07-16-2013, 12:24 PM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Im not believing this.
Originally Posted by UberSilver View Post
Ditto.
Totally agree. If this person is going through transmissions so much then it has to be a hoax or the person honestly doesn't know how to drive a stick. There is a known issue with the C50 and syncros, but hitting it that frequently is a bit much to swallow. I will be interested to see what is really going on inside my tranny I just swapped out in my car. I have spoken with at least a half dozen folks that experienced the same issues with their C50 that I did which is not being able to downshift, having to shift into 2nd and then up to first when shifting from neutral, and from time to time having to force into gear just about when upshifting. This was happening prior to me even boosting the car. Then there is the grinding into 1st after full deceleration say for example at a stop sign or stop light. This is with no load on the transmission being at a complete stop after decel. Regardless having this happen consistently if that is the truth sounds to me like total abuse on the transmission as well as short shifting possibly.
On that note, does anyone even make upgraded syncros for the C50? Would you just need to try and find instead the TRD transmission from the Vitz?
blown transmission, help!, transmission
2010 Yaris lift eric81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-13-2015 08:57 AM
January 2010 Yaris Sales Thirty-Nine General Yaris / Vitz Discussion 8 02-03-2010 12:50 PM
