![]() ![]() Drives: 08 hatchback Join Date: Jun 2011
Looking for tires: What size is the best on 17 inch rims?
I have 17x7 inch wheels. which size is the most comfortable and sporty at the same time right now I'm riding 205/45/17. should I stick with that or go with 215/45/17 or 225/45/17 or 215/50/17 or 225/50/17????????? when I turn the steering wheel all the way I rub with the 205/45/17 will the other large sizes be considerably worse????
Any of those other sizes will just make it worse. You'd need to go smaller like 205/40
Mr. 155 and climbing
Yup...I had 205/40/17s on my DxR 7" wheels and the car LOVED them. NEVER rubbed ever.
![]() ![]() ![]() Drives: peArL yAvItZ!! Join Date: Jul 2009
The closest size to OEM spec is the 205/40/17. 100% no rub and look much more sportier due to lower profile. ;)
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres |
If you're not lowered, 205/40/17's look very, very tiny. Stick with OEM size 205/45/17 with stock suspension. As long as you're running proper offset, the lock-to-lock rubbing is not serious.
#6 | |
Im lowered 2 inches and the ride is too stiff. if I get larger sidewall tires will that help maybe like a 205/50/17 |
#8 | |
![]() If your problem is really being too stiff, my advise is to revert back to stock springs and go OEM 205/45/17. If you wanna to have BEST of comfort and some look to remove the tires gap, go for 205/50/17.
| 16 inch or 17 inch rims? | helladopebev | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 11-19-2013 01:56 AM |
| Looking for 15 inch stock steel rims | hop | Canada | 2 | 01-21-2010 07:18 AM |
