Old 01-01-2014, 02:53 PM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yes....the way the ECM handles via the speed sensor and cluster is that once the speedometer returns that 118 has been reached then the ECM leans out your fuel drastically to "force" you to reduce speed. I found that it would drop me depending on the suspension setup (for example wheel/tire combo) I could lose between 8 on the high end and 4 on the low end of mph lost. I found this out over 20+ land speed runs which gave a great way to figure it out. Essentially riding off the speed limit cut is a bad thing.
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
LOW RPM @Idle speed = Bad Volt Generation? jp_costarica General Yaris / Vitz Discussion 4 06-14-2012 04:56 PM
The most economical speed for the Yaris. Ilovemyyaris Fuel Economy Forum 3 03-19-2012 11:33 AM
RPM at 60 mph 5 speed manual mark schofield DIY / Maintenance / Service 13 10-08-2011 12:14 AM
