![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Squeezing some serious rubber,SM setup
Test fitted my new setup for this season.... 275/35-15'' Hoosier A6 for the front! 225s going on the rear. Front wheels are 15x9 with a 15 offset, rears 15x8 with a 25 offset.
Ptuning.com |
![]() ![]() Drives: 2002 Toyota Yaris T-sport Join Date: Jan 2014
Fat. Very Fat. Rubber.
How much power are you putting onto those and what kind of clutch are you running?
2002 Toyota Yaris T-sport ![]() 198X BMW E30 modified race car ![]() 1975 Ibanez "Les Paul custom" |
Nice. Are you reworking the fenders to accommodate?
320whp+ . ACT 6 puck
Ptuning.com |
I am most likely getting shorter coil springs in the front, so I can raise the perch ( so tire doesnt touch with more camber). I need to run more negative camber with these tires, so they will be in at the top more than it is now.
Ptuning.com |
Serious power indeed. And I thought you wouldn't be running some ole stock clutch with that rubber needed.
2ZR swap. DO IT! Ask how!
Insanity. I'm assuming this is for track use, and not tight-course autocross?
Mr. 155 and climbing
You will be able to easily pick him out of a crowd. He will be the one with the seam splitting left leg and normal sized right one....hahahaha
It is intended more for autocross, and circuit cross style ( standstill start, one hot lap) time trials. The good thing about being in the DC region, is that I get to Compete with the national SMF champion and other really strong competitors. 275s up front is my only chance to be a front runner.
Ptuning.com |
Thats awesome, thats the same tire size I was going with this year. Good luck man. I hope to make an event up north once this year. I will be in FSP probably.
Form>Function
so nasty. Are those CCW's too?
Avid 12 is the wheel. I came across a crazy deal, $219 for all 4 brand new. Reason; wheel paint color was off. I did an alignment today and dialed in a good starting point for camber, the tire sits darn near flush. The picture above was with a 3mm spacer, which is no longer being used. The inside of the tire clears the coilover body by about 4mm. These wheels fit PERFECTO
Ptuning.com |
Those are some phat ass wheels.
![]() I'm guessing you rub like crazy on rough roads?
This wheel and tire combo will probably never see a public road, so I'm not to worried about rubbing issues. I run 450lb springs up front along with a 300lb sway bar, so far that fender to tire gap has never closed.
Ptuning.com |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
A 320whp Yaris in Virginia. I need to see it !
Hahaha. It's still power by a 1NZ though so it counts.
| )) Steering wheel hub setup (( | aucorium | Cosmetic Modifications (Exterior/Interior) | 4 | 04-30-2011 04:09 PM |
| My suspension setup: Breakfast Blend for the angry panda | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 07-26-2010 03:56 PM |
| New "milder" Setup | Loren | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 04-26-2010 10:08 AM |
| N/A setup | Maitre_Te_Te | Performance Modifications | 22 | 12-07-2009 03:24 AM |
| Yaris 2001 - serious problem | adnanmalik | General Yaris / Vitz Discussion | 10 | 06-19-2006 08:59 AM |
