Old 01-25-2014, 10:55 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
The gears as far as I know are not interchangeable. 5th gear in the 6 spd only goes about 145-150km/h and has the engine turning around 4100 rpm at 100km/h. Not ideal for every day use.
Old 01-25-2014, 01:20 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
In theory the gears from 3rd to 5th could be interchanged if the shafts have the right splines, but 6th gear would require some investigation. If you need to drop the freeway RPMs in 5th gear, get a 5th gear set from an '03 Matrix C59 gearbox. Most of the 5-speed gearboxes have a 0.815:1 5th gear, but both the 5- and 6-speed gearboxes from that gen matrix have a 0.725:1 5th/6th gear respectively.
At this point, the only way to know for sure with the other gears is to get the parts and see if they fit.
Tags
6 speed, conversion, gearbox, transmission
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
