Old 09-03-2015, 11:41 AM   #1
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
Originally Posted by mr9865 View Post
2012 as well, just showing signs of rust above the license plate
As a follow up to this post, Toyota covered the sanding and repainting of my hatch this week. There was about 5 pin sized rust spots, and a lot behind the license plate. Apparently there was nothing under the chrome trim piece.
mr9865 is offline   Reply With Quote
Old 03-15-2014, 11:03 AM   #2
Hershey
Geesh , that's a big hole . Any water getting into your trunk ?
Old 03-15-2014, 11:54 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
Wow. My 2005 xB (in 2006) was rusting at a door weld on the driver's side. A number of other owners had the same issue.
Does Quebec use salt on its roads?
Yep, we use salt here. So far, no weld is rusting on my 07. And garage parking it did not help (heat and salt makes a big mess)
I removed the chrome trim to clean the area and protect it a little bit from rusting more. It's not bothering me much since my car is not the cleanest anyways..
Old 03-16-2014, 12:53 PM   #4
dip1
Drives: 2012 Yaris SE
Here is some of the rust! Cars a little dirty...
dip1 is offline   Reply With Quote
Old 03-16-2014, 01:26 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
i have seen same problem on Highlander same spot 2011 up gets fixed by Toyota.
Old 03-16-2014, 11:01 PM   #6
Hershey
. Should get that taken care of under the warranty .
Old 03-17-2014, 01:45 PM   #7
matti
Drives: 2017 Yaris L (5sp manual)
dip1, thanks for posting the pictures. My white 2012 Yaris L has similar rust, but not as bad as yours. When I get an oil change this spring, I'll ask about warranty coverage on the rust spots.
matti is offline   Reply With Quote
Old 03-17-2014, 02:22 PM   #8
dip1
The chrome on the front air dam is rust colored too. I need to wash it next couple of days and really look the car over. There probably is more somewhere else...
Darrell
Old 03-18-2014, 10:00 AM   #9
YodaBird
Drives: Gray
Interesting, I should check mine once again. Did you get rust protection ?
YodaBird is offline   Reply With Quote
Old 03-18-2014, 11:22 AM   #10
Hershey
There's rust coverage that comes with the car like that of the bumper to bumper and powertrain . Should be at no cost .
Old 03-18-2014, 05:55 PM   #11
YodaBird
Drives: Gray
dip - You are most likely still under warranty, they will fix that, whether it's replacing the body or whatever they will fix. Do it now before your warranty expires.
Old 03-19-2014, 08:27 AM   #12
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
The corrosion warranty usually specifies "perforation" or "rust through" and Id be surprised if a cursory detailing and touch-up isnt all they do for it at this point.
Given the OP's location, (and judging from the pictures) acccumulated dirt, including what is likely "road salts", aren't helping matters.
Washing your car regularly year-round especially ones that get used in "rust belt" states where they DO salt the roads, and have dirty rain is more important in the winter months for this very reason.
I know it seems silly to wash a car when snow-ice-rain-crappy weather as much as guaranteed, but doing so is actually more a preventative measure than a cosmetic one.
The old saying "a clean car lasts longer" comes to mind.
I'm the Prez at my house...in fact I cruise around in YarForce One!
When I'm not driving my Yaris, I'm doing this:
http://gogogordy1.wix.com/scooter-aficionado
Gogogordy is offline   Reply With Quote
Old 03-19-2014, 11:40 AM   #13
roxy1
Drives: 2014 yaris 5 speed
^this. I wash my cars regularly, especially in the winter. most of my cars ive kept 10 year and 200,000 miles and always end up with very minimal rust.
roxy1 is offline   Reply With Quote
Old 03-19-2014, 11:58 AM   #14
IllusionX
In this case, it really depends on the dealer. My sedan trunk lid had similar rust.. and also under the license plate, and they repainted it under warranty.
Old 03-23-2014, 12:21 AM   #15
YodaBird
Drives: Gray
I found rust the size of my pinky finger nail, within the back headlight area, you can't see it, unless you look real close. The rust is light brown, I believe it still can be removed. The problem is finding something that can remove the rust.
This winter has been real brutal, especially the extreme cold temps, first time in a long time I inspected most of the car, car door hinges etc. Since this rust spot is small, best to remove it while it remains small.
Any suggestions for a rust removal product ? Toyota won't do nothing on this rust spot since it's not visibly noticeable, I don't even have to ask, I know from a mechanic at the dealer.
Old 05-01-2014, 11:25 AM   #16
matti
I just wanted to followup that, during my oil change this morning, I had the service manager look at the rust spots that had formed on my 2012 Yaris L hatch. I have rust similar to the OP, but not as bad. The service manager took some pictures and will send them off to regional (?) for the okay, but he said they should be able to cover the rust repair under warranty, no problem.
Old 07-20-2014, 11:21 AM   #17
Deadliestflea
You need to just take care of it better.....but hindsight 20/20 cause once the rust starts your gonna have problems from now on.
Deadliestflea is offline   Reply With Quote
Old 07-20-2014, 12:48 PM   #18
YodaBird
Drives: Gray
The Rust I found, can be cleaned but it's in a spot none of you would ever look :)
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Yaris design oversight... abattle General Yaris / Vitz Discussion 54 09-24-2010 04:52 PM
