#19 | |
Only Happy When it Rains
And yes, the Prius barely fits into the midsize category only because they made it as open as possible. It is still on the smaller size of the midsize spectrum, and unless you do a ton of city driving and drive to get the best gas mileage, as you might do, it isn't worth it. But hey, you want to use the masses to judge fuel economy? Fine. fuelly gets 47. Which is absolutely pathetic. The last time I actually had to drive on a freeway, I did that in my Yaris. Now let's actually be honest here. The Prius and the Yaris are cross shopped. The main reason to by both is because of gas mileage. I looked at both before I bought my Yaris in may of 2006. I, like many on here went with the Yaris because the extra gas mileage simply was not going to make up the price differential short of $8 a gallon gas. And since you like fuelly so much, here is mine. ![]() I almost never do anything like freeway style driving to boost that number up, the closest I get is state highways with tons of lights, cars stopping to take turns, and the like. And unlike most hypermilers, I use my cruise as much as possible, I very rarely drive to endanger like they do, about the only thing I do is drive the actual posted speed limit, and not act like a dumb ass drag racer.
Colin Chapman disciple |
#20 | |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
Thanks for chiming in. Look, I'm not anti Yaris. I bought one for my kid and think is a good and thrifty car for a single person. But, saying that Yaris gets the same MPG as good hybrids is just a lie. |
#21 | |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
fuelly results aren't useful unless you look deeper into the numbers. looking at peoples numbers who are recording primarily highway, you will see plenty of low-mid 40's. likewise, many of those mid and upper 30's involve a higher percentage of city driving. the results are from all over the place, including places in Europe where they don't have much chance to do the kind of highway driving we do here. there is also a trend of the manual transmissions beating epa estimates more handily than the auto. you want to see "real world" 5 speed yaris numbers from this country, here you go. from fueleconomy.gov. http://www.fueleconomy.gov/feg/Power...is&srchtyp=ymm you can see the mpg in bold. the last two numbers before the date are city and highway percentage. it is clear that plenty of people driving a higher percentage of highway are doing better than mid to upper 30's. it is consistent with what I regularly achieve by just driving reasonable. looks to me that highway numbers are a lot better than mid to upper 30's, n'est–ce pas?.....more like upper 30's to low 40's. I can confirm than one not need be a hypermiler to get these numbers. 1 50.2 OR 10 90 04/14/2008 2 47.5 OR 10 90 06/06/2011 3 44.3 WV 0 0 07/15/2009 4 44.2 IL 10 90 10/21/2008 5 43.8 UT 31 69 07/26/2008 6 43.4 ME 20 80 05/29/2008 7 43.3 NH 15 85 06/12/2008 8 43.0 NH 10 90 10/10/2012 9 42.5 NC 20 80 09/23/2008 10 41.5 OH 40 60 07/16/2008 11 41.3 GA 80 20 07/30/2009 12 41.1 CA 20 80 07/20/2008 13 41.0 OH 30 70 07/30/2008 14 41.0 TX 20 80 12/05/2012 15 41.0 MT 46 54 02/13/2009 16 40.7 UT 30 70 05/27/2008 17 40.2 NY 47 53 06/18/2009 18 40.0 FL 40 60 09/05/2008 19 39.9 UT 37 63 11/11/2008 20 39.8 FL 37 63 07/26/2009 21 39.3 CA 30 70 10/19/2008 22 39.3 CA 18 83 04/06/2008 23 39.2 PA 70 30 05/08/2008 24 39.2 CA 70 30 06/28/2008 25 39.0 NC 20 80 10/04/2008 26 38.8 NY 20 80 11/17/2009 27 38.6 IL 40 60 11/12/2007 28 38.5 NC 55 45 01/28/2008 29 38.4 WA 46 54 01/02/2014 30 38.4 CT 37 63 07/11/2008 31 38.3 WI 31 69 02/26/2010 32 37.2 WA 33 67 12/12/2007 33 37.0 IL 30 70 05/03/2008 34 37.0 SC 20 80 05/31/2008 35 36.6 IN 50 50 04/17/2008 36 36.6 40 60 08/13/2008 37 36.2 CA 20 80 06/03/2008 38 36.2 CA 61 39 03/30/2009 39 35.0 MN 50 50 01/30/2008 40 34.0 IL 60 40 08/03/2009 41 32.1 CA 90 10 08/14/2008 42 31.9 CA 50 50 10/16/2009 43 24.9 CT 90 10 01/02/2008 Last edited by roxy1; 05-20-2014 at 06:47 AM. |
#22 | |
if someone wants the prius for more room, nicer interior, quieter drive, etc...that's fine. if they want to argue its worth the extra cost for what they will save doing mostly highway driving, that doesn't hold much water. even at 40 mpg's vs 46 mpg's (real world highway, which is a legit real world number for highway prius driving)and 15,000 miles per year and $4/gallon gas, the prius only saves $196 per year. |
#23 |
What scares me is the public is accepting skyrocketing increases in the price of their cars for questionable "advances" like hybrid drive, ABS, 12 air bags, traction control, increased size of vehicle (compare an 85 Camry with a 2014) and many others
My 1980 Subaru Hatchback was $4600 OTD, 88 VW Fox $7000 ditto, 2001 ECHO $13.100, 09 Yaris Im not sure because I had a 0 percent loan but Im thinking ~$15500. A new Yaris OTD is nearly $20k.
Synthetic Oil: Its All In Your Head Last edited by bronsin; 05-20-2014 at 10:48 AM. |
#24 | |
but, I will take the airbags. they could leave everything else out. |
#25 | |
There is no disagreement here. My point is that most people live and drive in cities, and no car (even small) can touch hybrid city MPG. This is well reflected in the real life fuelly numbers. So pointing out that you or someone can somehow (probably slow driving) get 50 mpg is useless. Look, I can get 70 mph in mu Prius if I drive it slow enough, but I have enough sense not to brag about it. As to what's "worth" the cost and what's not, most people spend $30,000 on a new car in this country. They typically get a gas guzzler. Is it "worth" it? Apparently it is for them. For full disclosure, I paid $21,000 for my prius when new in 2010 and very happy with the car. I owned 11 different cars so far (all imports, 4 Toyotas) and Prius is the best car (but not most expensive) I have ever had. Very "worth" to me. If you really wanted to save some money on a car, you wouldn't buy Yaris either, you would buy a beater manual Saturn and they deliver 30-40 MPG. My friend recently bought a 2002 one with low miles (no oil burning) for only $1200 and he likes it a lot. Any Toyota of this age would be in the $5000 rage. |
#26 |
#27 | |
How many of those would they sell?
#28 |
I have to point out that many city commutes are relatively short, or if there is city driving included in a longer commute, that portion is relatively short.
many people get away with poor mileage cars in short city commutes because even at 15 mpg and 60 miles per week (of true city commute), it costs only $16/week. if I lived in the city and had an all city commute, I probably would get a 15 yr old beater that gave me 15 mpg. at least most folks I know that live in the city and work in the city don't drive very many miles per week. |
#29 | |
let me know when you see someone on here bragging about driving like granny and getting 50 mpg in their yaris. |
#30 | |
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
While your sooooo happy with the prius, lets not forget the extra 1/2 ton of toxic waste the earth needs to deal with, when I prius is wrecked.
This is something very few(if any)Prius owners every deal with or think about. The Prius is loaded with toxic waste! And Prius owners are helping to pollute our planet, Just so they can feel warm and fuzzy about using less gasoline. Quote:
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
#31 | |
#32 |
![]() ![]() ![]() Drives: 2012 Yaris L, 2020 Yaris LE HB Join Date: Jan 2013
What I love about the Yaris is that one can achieve around 40 MPG average with a plain-old gasoline engine and an automatic transmission in a car that is much less-expensive than a hybrid. For me, that makes some economic sense in the long run. Just my two pennies...
#33 | |
Thats about 7 years with my 23k per year driving. I'd be pissed if the dealer told me, at the 7~8 year mark, $4000. please!
![]() Quote:
#34 |
Also, then the old batteries go down to Mexico to poison poor kids. What's wrong with this picture?
http://sadhillnews.com/2011/12/09/bu...kill-a-mexican
#35 | |
#36 |
Wait, sounds like a good plan. Kill of the mexican drug lords with lead poisoning.
| Save thousands and BIG MPG almost PRIUS | jay cobbs | New YARIS Purchase Forum | 6 | 08-28-2012 08:38 PM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-01-2009 11:12 PM |
| Darb - Photo Scavenger Hunt | Darb | Photo-Video-Media Gallery | 3 | 03-01-2009 09:02 PM |
| Black Yaris - Photo-Scavenger Hunt | Black Yaris | Photo-Video-Media Gallery | 2 | 03-01-2009 04:13 PM |
