![]() ![]() Drives: 2013 yaris Join Date: Sep 2014
water sloshing sound?
when ever i star my 2013 yaris i can hear this sloshing sound out of the car is this normal or was it me that never heard that sound?
I am also interested, I have the same sound in my 2013. I always check the coolant level, it's always full.
25, 550 MILES!
I hear it in my 2013, too...I'm guessing it's the gas in the tank...
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Did it rain a lot recently?
Not here in San Diego.
If the sloshing sound is from the dash, then the AC box condensate drain is likely clogged.
just verified mine not cloged still have the water sloshing
I noticed my gas tank sloshing recently. Can only hear it when the car is at idle and no ambient noise
I drive a 2010 hb |
sound source is from the dash not from the gas tank when the car is starting is when the car makes the sound
In that case it is likely condensate in the air box. How did you go about trying to clear out the drain tube? You need to insert something all the way up the rubber hose to poke though whatever may be blocking the end within the box.
took out the hose used a wood stick and had nothing in there
The only other water containing item behind the dash (other than things you might shove in the glove box) is the heater core. The only way I could see it making that kind of noise would be if it had air trapped in it from a prior coolant change.
Drives: 2014 Yaris LE Join Date: Jun 2016
I hear the same noise in the rear of my car when I start to drive it like fluid slosh. Is this normal or need to be serviced? Thanks
I was going to say air in coolant system
Jack up the front of the car, take off rad cap, start it, see if you get bubbles
![]() Drives: 3G3DMT Join Date: Dec 2012
Water in the A/C unit will slosh, that's not what this noise is.
It's more like walking in rubber boots that contain water, that squelch noise. The noise emanates only on the initial movement of the vehicle. Ensure manual gearbox is in N, depress clutch pedal, start the engine, select first gear, apply foot brake, release hand brake, engage clutch, within less than one revolution of the vehicle wheels one can hear the squelch. The important part here is the revolution of the wheels. No noise until the vehicle is in motion. Happens in forward or reverse. I think it is part of the ABS system charging itself and getting ready for a traction control demand. Mine has done it since new, still does, and continues to stop well. Probably happens in Auto gear box models too. |
#16 | |
![]() Drives: 2008 Yaris automatic Join Date: Jul 2009
Reading this thread might be worth consideration:
http://www.yarisworld.com/forums/showthread.php?t=6053 It was the case with my '08.. and unplugging the drainage tube fixed it. |
Drives: 2010 Toyota Yaris Join Date: Jul 2018
Update
Thanks for the advice on this thread. I am technically illiterate and wasn’t able to pull up the pics but figured this one out. Found the drain hose, used a straight plastic stick to break up debris. This alone didn’t do the trick but I popped it back in and then “milked” it like others suggested and probably drained two liters of water out. This is the second time this has happened to my 2010, first one was about 5yrs sho and I didn’t know better and just paid Toyota. Now time to get a cabin filter in there...
| 2007 hatchback making a weird whirring sound | robkay | DIY / Maintenance / Service | 20 | 03-19-2016 07:53 PM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 06:35 PM |
| sloshing sound when starting up | CPALK719 | Third Gen Yaris General Discussion | 10 | 03-27-2012 06:59 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-05-2011 12:56 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 04:11 AM |
