Old 01-20-2016, 12:58 PM   #7
Sarvesh
Drives: Toyota Yaris 2012
The light blue large wire is the low beam headlight (ground that wire to turn them on).
The pink large wire is the high beam headlight (ground that wire to turn them on).
The green wire is the parking light wire (supply +12V to turn them on)
The white wire is an always on +12V that supplies power to the green wire via the headlight switch.
For an ignition switched power wire you have to look at the ignition switch connector - The pink wire on it is +12V switched power.
The white/black stripe wires are grounds
CTScott...I wired the system accordingly, however when I switch full beam it doesn't work. Likewise the system says it should switch off for 5 seconds when the car is started to avoid battery drain but it's actually starting the car with the headlight on when I turn the key. Could you please help.
Sarvesh is offline   Reply With Quote
DIY: 2006-2011 Yaris OEM Cruise Control Complete Installation CTScott DIY / Maintenance / Service 172 10-27-2025 03:04 PM
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 04:59 PM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
zage turbo kit..! just need some help joseyaris Forced Induction Forum 12 10-29-2009 09:35 PM
Greddy xB kit vs Greddy Fit kit ellenbetty Forced Induction Forum 52 09-29-2009 09:42 PM
