Old 02-14-2016, 12:17 PM   #1
z0mb13k1ll
z0mb13k1ll's Avatar
Drives: '15 Dodge Challenger
Ah, i found the thread you mentioned http://www.yarisworld.com/forums/showthread.php?t=8985
but I don't think that it's the right ;look for me, saw someone commented on it saying they used some 3m plastic with a few holes in it, might try that and see if you can tell if it's there at all. or put something behind the grille, it's pretty easy to pull off since i purposefully left those 2 screws holding the grille on the table last time i took the bumper cover off
z0mb13k1ll is offline   Reply With Quote
Old 02-14-2016, 06:31 PM   #2
That one is pretty hideous looking. There was another where a sheet of foam was used and it looked a bit more tame.
Old 02-16-2016, 02:15 PM   #3
Pokey
Drives: 2010 4 Door Hatch 5 Speed
I made a grill cover out of black cloroplast and secured it with toggle bolts (the kind that spring open. Makes a HUGE difference at -36C
Haven't needed it this year, but I store it under the floor with spare off season
Pokey is offline   Reply With Quote
diy, grille, sedan, yaris 2007
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 12-01-2013 12:07 AM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 04:30 PM
DIY Tow-Hook Cover Plate Mod Yarisduder DIY / Maintenance / Service 4 05-30-2010 12:51 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 06:55 PM
