Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 08-29-2016, 03:30 PM   #11
CoryM
Drives: 2009 5-door, 5-speed
Interesting about the video.
From my experience, it is far more common for sketchy shops/dealers to sell people work they do not need, than it is to sell work and not perform it. Was the cabin filter just grey, or did it have a bunch of junk in it? The reason I ask is some cabin filters are impregnated with carbon to absorb smells. They are grey when they are brand new.
The typical cab filter service interval is 2yrs/24k KM. If you drive dusty roads or park under trees it can be far less though.
A/C services are not needed and, far as I have seen, not part of any manufacturer's required service. What they typically do is inject a can of top-up refrigerant which is not required and potentially harmful (A/C refrigerant is meant to be a set amount. Adding more than spec can damage the system. Also the top-up can are often not the correct refrigerant). If your car is losing refrigerant, it has a leak and should be fixed properly. Not topped up. They also typically inspect your cabin filter, and spray a deodorant in there. Unless your a/c smells like shoes, it's not required.
Does this dealer also sell oil additives with every service? And did they charge labour to replace the cabin filter?
Cheers.
Shameless dealer plug NEexpat General Yaris / Vitz Discussion 0 07-03-2012 05:05 PM
30,000 mile service, this should get you going minicorolla DIY / Maintenance / Service 44 11-21-2010 11:09 PM
compensation from dealer 08blackyari General Yaris / Vitz Discussion 8 09-02-2010 12:05 AM
Service at Toyota local dealer beZzZ DIY / Maintenance / Service 22 05-07-2010 08:23 PM
Someone Please Help With SET & Local Dealer Nightmare! sanityassassinv2 General Yaris / Vitz Discussion 32 11-26-2008 12:32 PM
