Old 12-09-2017, 04:12 PM   #9
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Removed and checked the OCV filter. It was a fairly straight forward job. Had to remove the serpentine belt and tilt the alternator fully forward.
Filter is spotless. I'm beginning to believe that my ticking sound may be exhaust manifold related. The ticking completely stops after the engine is at operating temp for 5 - 10 minutes.
Here is a pic of the OCV filter exactly as it came out of the engine - no cleaning.
CHECK ENGINE !!! Dealer Blames (Oil Control Valve) netspec239 General Yaris / Vitz Discussion 15 08-11-2018 03:31 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
Oil Control Valve weston_sagle Willing to Buy by private party 4 07-10-2011 08:03 AM
When should I start using synthetic oil?? trwxxa DIY / Maintenance / Service 68 06-29-2009 06:16 PM
