Removed and checked the OCV filter. It was a fairly straight forward job. Had to remove the serpentine belt and tilt the alternator fully forward.
Filter is spotless. I'm beginning to believe that my ticking sound may be exhaust manifold related. The ticking completely stops after the engine is at operating temp for 5 - 10 minutes. Here is a pic of the OCV filter exactly as it came out of the engine - no cleaning.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-09-2017 at 04:25 PM. |
| CHECK ENGINE !!! Dealer Blames (Oil Control Valve) | netspec239 | General Yaris / Vitz Discussion | 15 | 08-11-2018 03:31 PM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 12:33 PM |
| Oil Control Valve | weston_sagle | Willing to Buy by private party | 4 | 07-10-2011 08:03 AM |
| When should I start using synthetic oil?? | trwxxa | DIY / Maintenance / Service | 68 | 06-29-2009 06:16 PM |
