Before replacing my belt, I ran the engine and saturated the spinning pulleys with brake cleaner a few times. I didn't really care about the belt as I was changing it. I think the pulleys can get glazed when a belt slips. Cleaning the pulleys may help. I agree with tmontague about finding the loosest tension without slipping. So, if you have squeaking, tighten it a bit, maybe a couple of mm at a time until the squeeking stops under all conditions. Since putting the Continental (former Gatorback) on mine, I haven't had so much as a chirp.
| Tags |
| belt, squeeling |
| Belt Squeeling. | alweasel | General Yaris / Vitz Discussion | 4 | 09-27-2019 11:07 AM |
| Oil change shop says alternator belt is cracked | RMcG | DIY / Maintenance / Service | 19 | 05-02-2018 07:38 AM |
| Blitz Supercharger Belt Slip @ Higher RPM? | Freestylin | Forced Induction Forum | 20 | 09-06-2017 07:32 AM |
| Belt Squeeling like a Mofo | gumby002 | DIY / Maintenance / Service | 7 | 09-10-2016 05:38 PM |
| DIY how to change you belt in 10 minutes without breaking VVTI solenoid | YarisSedan | DIY / Maintenance / Service | 2 | 04-12-2013 10:41 AM |
