13mm Penguin Hub Spacers Installed
Finally got around to installing the spacers. It was a fairly easy job with the two biggest challenges being disconnecting the wheel speed sensor connectors (was a little worried that they'd break) and separating the hub from the rear suspension beam after the bolts were removed.
The final effect was definitely worth the cost and effort. It makes a big difference! Unfortunately I didn't take any before pics from the same camera angles. ![]() ![]() ![]() ![]() ![]() ![]()
![]() ...and now for a set of Tein S. Tech springs
| PG Hub spacers group buy | Vitz_Q8 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 45 | 11-15-2015 02:10 AM |
| FS Penguin 10mm Rear Hub Spacers (Brand New) | skeck | Items for Sale by private party | 5 | 03-01-2013 04:24 PM |
| 13mm Penguin Garage Rear Hub Spacers Installed! | Jackalope1 | Cosmetic Modifications (Exterior/Interior) | 20 | 03-29-2012 12:22 AM |
| installing Penguin Garage rear hub spacers! | Tamago | DIY / Maintenance / Service | 101 | 05-21-2011 12:29 PM |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
