Old 12-25-2018, 10:03 PM   #1
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
Originally Posted by myfirstyota View Post
The hubs are NOT required when keeping the xd transmission and axles. The xd axles are larger on the trans side yes but they slide right into the 4 lug Yaris hubs. This also applies for the rear hubs. Xd, Yaris and Yaris SE disk brake axles all share the same size hubs.only difference is the lug count.
why wouldnt you swap to 5x100 more wheel options 4x100 is garbage when it comes to wheels. the difference in strength is minimal and you get bigger brakes and you can even add corolla brakes if you want which are massive and powerful.
DarkShadowFox is offline   Reply With Quote
Old 12-25-2018, 10:40 PM   #2
tmontague
tmontague's Avatar
There is a ton of great aftermarket wheels offered in 4x100 unless you want to go to an all show and no go 17" + wheel.
Corolla brakes are not needed unless you want the bling factor which it hardly benefits. It upsets the brake bias unless you are going to the trouble of dealing with an aftermarket brake cylinder and/or proportioning vakve and brake booster. All that is needed is proper brake pads to deal with the temp range you operate in. This will give you more brake than you ever need and much more than a corolla brake.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 12:56 PM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 11:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 09:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 10:12 AM
1zz swap...is it worth it??? jouna Performance Modifications 12 11-10-2009 10:33 PM
