#1 | |
![]() Drives: Toyota Yaris SEdan Join Date: Oct 2016
20w50 is too thick, i think its more meant for track driving. and also there is no good quality 5w30 in the market here, that's another reason to switch |
#2 | |
You really want to look for something 10w, 15w or 20w. Sent from my CLT-L04 using Tapatalk |
#3 | |
Oils are thicker at colder temps even multi weight oils. A 5w means it flows like a 5 weight oil at 0* and a 0w oil flows like a 0 weight at 0*. It does not mean the oil weight is 5 or 0 at 0*. If that was the case than our passenger car pil would be thinner after being left in the freezer than it is left on the shelf To the OP, are you monitoring pil pressure? If you are not then you have no reason to increase your oil weight above the factory spec. The only need for this is if you are suffering from oil pressures below Toyota's spec.
#4 | |
thanks man !!! |
#5 | |
![]() Drives: Toyota Yaris 2016 Join Date: May 2016
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| oil sweat for '07 YARIS RS check engine on | radu1976 | DIY / Maintenance / Service | 4 | 04-15-2019 05:14 PM |
| 2008Yaris w/ 131000km due for oil change.Conventional or synthetic?Change filter too? | BlackTy | DIY / Maintenance / Service | 21 | 05-21-2018 10:56 PM |
| Oil Return on upper oil pan sub assembly | BoostedTRD | Forced Induction Forum | 6 | 11-10-2014 10:23 PM |
| Question about a changing oil level | Goose | DIY / Maintenance / Service | 3 | 11-02-2010 10:32 PM |
