Old 04-15-2019, 10:49 AM   #6
Bony_ahmed
Drives: Toyota Yaris SEdan
Originally Posted by komichal View Post
If you are really in Dhaka - why would you want to use 0W oil???
AFAIK the temperature never goes below 0 degrees Celsius there. You should look for 10W50 (you should still be OK even with 20W50 but that is out of Toyota specs I think).
Well i live in Dhaka, and thinking about driving using a thicker oil. My main concern is about the 40 weight, will it ruin the engine and will it drop my MPG?
20w50 is too thick, i think its more meant for track driving.
and also there is no good quality 5w30 in the market here, that's another reason to switch
Bony_ahmed is offline   Reply With Quote
oil sweat for '07 YARIS RS check engine on radu1976 DIY / Maintenance / Service 4 04-15-2019 05:14 PM
2008Yaris w/ 131000km due for oil change.Conventional or synthetic?Change filter too? BlackTy DIY / Maintenance / Service 21 05-21-2018 10:56 PM
Oil Return on upper oil pan sub assembly BoostedTRD Forced Induction Forum 6 11-10-2014 10:23 PM
Question about a changing oil level Goose DIY / Maintenance / Service 3 11-02-2010 10:32 PM
