Old 04-09-2020, 11:43 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Seeking Advice - 17" Alloys
I have a chance to pick these wheels up for a good price. I would install 205/45R17 tires.
I think that they are polished aluminum and I have requested higher res images from the seller. I could polish them. If not, I could repaint them in silver or just re-clear them.
I think they would look good, but I am concerned about how rough the ride would be. I've read the aftermarket wheels and tires thread but not much info on ride quality.
So, share your thought, please.
Old 04-10-2020, 05:12 AM   #2
kappa_md
Drives: Yaris RS2 2012
I had 17s in my Yaris before. Ride quality is good, but it will probably also depend on your suspension setup. If you are on stiff coilovers, it will probably have a harsher ride. Try to get lightweight 17s. I’m in Eibach ProKit springs and KYB Lowfer Sports dampers. TRD recommends 205/45/17 tires. I wouldn’t suggest anything beyond 7 inch wheel width cuz of rubbing issues. HTH
kappa_md is offline   Reply With Quote
Old 04-10-2020, 12:37 PM   #3
06YarisRS
Thanks very much kappa_md! Excellent advice. Unfortunately, before the guy could send me pics, someone dropped in and bought them. Very disappointing. I am running on stock suspension. I also have 10mm Penguin Garage spacers on the back, but they could be removed if necessary.
I have played around with Gimp and come up with some possibilities. I'm pretty sure that both sets of Hyundai wheels in the pics below would work. The wheel offset for the Yaris and Hyundai is 46. I have to get specs on the Eagle 192. I am trying to keep a stock look, but would love to go to minimally a 16", preferably 17". Budget is a factor. I'd be willing to buy straight wheels that need refinishing as I have a paint booth and all the necessary equipment. Images are bordered for Instagram.
Old 04-10-2020, 02:13 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
On my '07, I ran 15's, 16's, and 17's on stock suspension. I liked the look and the ride comfort of the 16x7 (with 205/50/16) best of all. With my '14, I only ran this 16" combination.
Old 04-10-2020, 03:26 PM   #5
06YarisRS
Yes, I think 16" seems like the ultimate size for the Yaris. 17" might be pushing it a bit, considering the condition of our roads. A 205/50/16 would work perfectly with my set up as, although it's slightly wider, it is very close in diameter. And, I'm almost positive that I could leave the PG spacers on if I used that size of tire.
What do you think of the 2008 Accent wheels? They are probably the closest I could find in design to the stock RS wheels. They have the same center cap diameter and depth etc. I think I could get set up reasonable affordably with a set of those wheels. It would be nice to have a couple sets of wheels to swap out when when I felt like it.
Here's a different pic of the Hyundai wheels. Obviously, disregard the read brake caliper. Haha.
Old 04-10-2020, 04:06 PM   #6
kimona
kimona's Avatar
^^^ I like that 16" Hyundai wheel. At one time, I actually thought about putting those on my car!
Your 10mm spacers will be fine in the rear with those wheels.
Old 04-10-2020, 04:29 PM   #7
06YarisRS
Yeah, they are nice, and should be both available and relatively inexpensive. Good to know they would work with the spacers.
Old 04-10-2020, 04:35 PM   #8
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
+1 on the Hyundai 16s
Old 04-10-2020, 04:46 PM   #9
kimona
kimona's Avatar
Here's a photo of my 2007 with 16x7, ET42, 205/50/16 on stock suspension.
Old 04-10-2020, 04:57 PM   #10
06YarisRS
For sure, eh. They are the closest I could find to the RS wheel. I had a chance to buy a set a while back and foolishly didn't pick them up. They were quite rough. I'm sure others will come up. There are several sets in excellent shape in Ontario, one set with relatively new tires. Alas, shipping would kill me. I'm keeping my eyes open and advertising in the virtual classifieds.
Old 04-10-2020, 04:58 PM   #11
06YarisRS
Absolutely stunning, Kimona!
Old 04-10-2020, 10:04 PM   #12
Neinris
Just wondering how much this affected your speedo? I'm on 185/60R15 and my speedo is indicating 2MPH slower than actual speed (for example speedo says 20MPH, but actual speed is 22MPH). Looks like my 2008 hatchback is dialed for the other stock wheel/tire setup of 175/65R14.
Old 04-10-2020, 10:55 PM   #13
kimona
kimona's Avatar
^^^ Surprise... After installing the 205/50/16's, my speedo was bang on!
Old 04-11-2020, 12:32 AM   #14
bentjazz
Drives: 2009 Yaris--3dr MT
I thought you sold your Yaris, 06YarisRS?
bentjazz is offline   Reply With Quote
Old 04-11-2020, 01:44 AM   #15
06YarisRS
Haha, I could never sell my baby, lol. I sold my 2008 LE.
Old 04-11-2020, 01:48 AM   #16
06YarisRS
I think that's what I'm going with. Have 3 sets to check out in the next few days. I posted a wanted ad and got 2 responses. Also a third set to look at at a wrecker yard.
Old 04-11-2020, 02:26 AM   #17
Neinris
Hmmm... what do I need to replace to get mine to dial in like yours? the ring that goes around the with the diff or the gear for the speed sensor?
Compare to my wheel/tire setup, you're going faster than me.
Or does yours pick speed signal from the abs?
Old 04-11-2020, 07:10 AM   #18
bentjazz
Electrical Journey Seeking Electrical Guru Advice longlivekel DIY / Maintenance / Service 15 10-29-2019 11:19 PM
**** Seeking Advice: I Need Frame straightening And what Insurance said + Pictures ** yarisa General Yaris / Vitz Discussion 7 08-18-2017 10:22 AM
Seeking advice head unit replacement - 2006 Yaris NCP91R aa11 In Car Entertainment + Electronics (audio / video / alarm) 2 01-01-2014 11:54 AM
Tire advice for 17" wheels coolj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 01-12-2011 02:06 PM
1st-Time Buyer Seeking Advice Oh,That Guy. New YARIS Purchase Forum 20 08-28-2010 01:13 AM
