#8 | |
![]() As for the rust at the subframe, my advice would be to get some oil or some other thin oil-based substance in there soon. Rust Check "red" in cans would be perfect. I'd literally unload half a can in each side. It may drip out, so putting an old blanket or something under there might be a good idea. The oblong rubber plugs just outboard of those supports should access the inner cavity. When I am done welding, I plan to drill a hole at the lowest part and install a 1/2" plastic plug. That way I can access the area easily when I do my twice annual rustproofing. Addition: If you do take out those rubber oblong plugs, you might note that the area is filled with sand and debris. I took the equivalent of about a cup of sand and crap out of each side. This is the 'design flaw in this generation of car (hatch, not sure about the sedans). That stuff in there holds water like a sponge.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-31-2020 at 11:31 AM. |
| Yaris T1 2007 Knocking Sound | varons666 | General Yaris / Vitz Discussion | 5 | 11-01-2016 04:38 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
| Help re my rattling Yaris! | lou3939 | DIY / Maintenance / Service | 2 | 03-11-2012 02:25 PM |
