Down With the Sickness
overkill?
um well i was in the heat of the moment and i picked up a ppi 3000w amp, 1000w rms, is that too much for the hatchback to take? its going to power up 2 12" mb quart rwe 304 subs, 500w rms 1000w max. please let me know if it better to sell than to keep. wouldnt want to buy a new window set for the rear.
Strength - Determination - Merciless - Forever |
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
lol I dont think you would bust the windows out, but your definately going to have a crapload of bass....
ive seen a couple videos on here from a member that got banned i think of multiple setups, and if he didnt blow the windows with the amount of bass he was bustin out, I dont think you will....excellent choice on the ppi amp though.......
i have heard his setup, i met him one time, he had 2 10" alpine type x subs driven by a kicker amp, i dont really know how much power he had, but yea i thought my ear drums were going to burst.
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
You'll get your eyes shaking for sure.
SPONSORED BY
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
You can't have too much bass
What do you have for the top end, can it keep up? The problem I see is nobody knows what the alternator can handle...that amp probably draws more amps at full pump than your alternator puts out for the entire car...
It's scary to think that half the people surrounding you are below average...
well i guess i will find out, so i think i will need a capacitor
from what I found the alt is only about 60amp. Although I ran two 12's and air cond. and didnt have a problem.
http://www.cardomain.com/ride/2336679 |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
I can't pinpoint the source, but the alternator is apparently 80 amp.
It was mentioned on the forums before; whether it is substantiated is another story. Even if you were to calculcate the amperage pull of an audio system, you have to consider that XX amps is only the peak amperage pull while the system is operating at its highest operating level. E.g. Your audio components may be pulling 70 amps after you have factored in the wattage and such, but that number is not the constant amperage pull on the alternator. The constant pull will generally be lower than 70 amps as you won't be operating all components at 100% efficiency. I haven't experienced any problems yet with my setup. I'm running 2 x 10" SW, 2 x 200 Mono, 1 x 840 4ch all without the need for a capacitor. Headlights and instrument lights do not dim during peak hits. It's probably not the most power hungry setup around, but I would say it's a typical setup for a car of this size. Just turn the volume down every now and then :)
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
basically, my setup wont ever be high volume, just for show it will
YARIS NEWBIE
Drives: YARIS 07 LIFTBACK Join Date: Jun 2007
i wouldnt worry about anything except someone stealing your gear .. sounds like your got the right gear for the job .. you def will bumping up and down your neiborhood .. wish i had it like that!
Hudson County, New Jersey
Mr. 155 and climbing
Don't have a can of soda in your ride when it hits
I currently have one BTA10200 tube and I am looking to add another...I was a little concerned myself with Alternator or battery issues...but maybe I am just too cautious.
i wouldnt want to bump around the hood, only at shows, there are trucks galore around my neighborhood, they have better setups im sure and more space to do more than me.
Hi!
change to plexiglass and pour concrete in your doors!
Mr Attitude
see:
http://www.yarisworld.com/forums/showthread.php?t=7225 caps are not a solution And Mikekrainets, the AC has nothing to do with power draw, no impact on your alternator...
