Old 07-22-2007, 12:52 AM   #24
mandriu
11b1p
mandriu's Avatar
Drives: yaris s
It's like with a straw. If you suck too hard the straw collapses. The thermostat is literally water tight. I initially removed the upper radiator hose at the filler tube and started the engine there was no flow. Since the cooling system was not pressurized I did not get any flow. I was amazed. I have it set pulling away because the thermostat is down there. Every diagram i have seen has the water leaving the engine at the thermostat
I am still not sure if the water leaves the engine at the thermostat. Anybody Know for sure?
mandriu is offline   Reply With Quote
Drinking from the black pump XOG Performance Modifications 1 04-20-2007 05:49 PM
sum dude asked if my car was electric... Blenjar General Yaris / Vitz Discussion 17 01-12-2007 10:39 PM
what water temp does cooling fan turn on gonzo452001 General Yaris / Vitz Discussion 10 11-07-2006 05:50 AM
[Detail] [as to make ] Auto Laudering Sérgio Barros Wash, Wax, Detailing, Exterior Repairs 4 08-22-2006 03:56 AM
