Old 08-25-2007, 01:36 AM   #1
kroxychc
Drives: 07 black sedan yaris
Question fuse box confusion!
hi
i got my 07 sedan yaris about 3months ago
i want to install an amplifyer in the back, and was wondering a few things about the fuse box
1. how do i get to the fuse box
2. which fuses will carry current when the ignition is on (remote 12v)
any info will be appreshiated
pictures please if you can!
kroxychc is offline   Reply With Quote
Old 08-25-2007, 01:47 AM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
The cigarette lighter gives off 12 volts when the ignition is turned on if your looking for a turn on for your amp. Other then that I think there is the full service manual on here somewhere that even shows the electrical layout.
slvryaris is offline   Reply With Quote
Old 08-31-2007, 11:32 AM   #3
duck
Drives: 2007 Silver Sedan
I'm not sure why you're looking at the fuse box?
In my opinion, you shouldn't be touching it.
Run a new power wire off of the car's battery, through the front firewall (there is a hole under the steering wheel for you), and run that power wire to the trunk. There you will connect to a fuse box (you can buy a small one for $10-$20 that will allow you to connect 1-4 devices with 1-4 fuses).
If you buy a car wiring kit, like a schosche (sp?) one from kmart for $20, it will have a large fuse already connected a few inches from the end of the power wire. place that end near the car's battery.
If you are looking for a turn on wire, that should come off the back of the radio or if you want something closer, tap off of a rear speaker.
duck is offline   Reply With Quote
Old 08-31-2007, 09:49 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
toyota cars are negative switched. so you can tap power from ANYWHERE in the car. as long as the fuse is big enough :)
Fuse Box Diagram MrJester DIY / Maintenance / Service 3 09-05-2013 11:40 PM
(3) 12" JL 12w3v2 in sealed Subzone Box! JustYYaris Items for Sale by private party 9 03-26-2007 12:13 AM
2007 S Sedan Questions drummer4christ DIY / Maintenance / Service 5 10-24-2006 01:10 PM
fuse box housing KSIbucky DIY / Maintenance / Service 3 10-17-2006 09:42 AM
Alarm Install Bones In Car Entertainment + Electronics (audio / video / alarm) 0 05-30-2006 03:25 AM
