Old 11-25-2008, 12:36 PM   #6
Originally Posted by TheSilkySmooth View Post
Super DIY write up. Thank you CTS for the effort! I am planning to put vinter tyres on My Daughter's Yaris and was concerned about setting a code as she is due for Emissions and saftey inspection this november. The SW seem like a good idea. CTS You dont have to shunt any of the cut wires to keep an open antenna out of the ECU?
Does anyone know if the 14" steel rims sold through Tire rack or Discount Tire Direct will clear the calipers? Her car has optional 15 inch rims. I wish to put a 165-70 snows on the front to get better force/unit area (µN/cm2) at the contact patch.
Thank you for helping,
- Papa
No shunting is required. The two wires we are disconnecting are both 12 V analog signals which the ECU is pulling through A to D converters. We shouldn't be able to pick up enough noise to cause a false signal detection.
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
