Old 07-07-2010, 02:11 AM   #1
bkndacn
bkndacn's Avatar
Drives: 2009 Toyota Yaris
2009 3dr liftback
< 33,000 miles
Bayou Blue
Problems: squeaky gears (DIY fixed )
Scuff on the back passenger-side bumper (Mom is no longer allowed to drive my Yoshi!)
His poor nose is riddled with rock dings (working on a DIY for that)
bkndacn is offline   Reply With Quote
Old 10-07-2011, 07:41 PM   #2
ramaz
Drives: yaris
I have a 2007 with 100,000 miles and runs very well
ramaz is offline   Reply With Quote
Old 10-20-2011, 10:59 PM   #3
Klink10
Klink10's Avatar
Posted in another thread. 2007, HB purchased new with 19,300 mi. Waterpump.
Old 11-03-2011, 12:14 PM   #4
jerome
Toyota
Drives: '11 5dr/5spd yaris
Purchased 5/29/11: 16 miles.
11/1/11: 3,058 miles.
Average: 139 miles/wk. :D
I'll check in-in a month or two!
jerome is offline   Reply With Quote
Old 11-04-2011, 09:43 AM   #5
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Purchased new Oct 2009. 23,000 trouble free miles. Click Fuelly icon for stats.
rick996 is offline   Reply With Quote
Old 11-04-2011, 10:21 AM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
purchased new@147mi. (driven to dealer) now at 33,000. trouble free so far besides that TSB w/ loose/rusty bolt issue in the front end
Old 11-05-2011, 07:57 PM   #7
randeez
Drives: 2008 3dr
2008 polar white liftback 3dr 5sp. bought it at 30,xxx miles, up to 32,500 now
only problem so far is a little stumble i get while idling...i dont have a tach so i couldnt tell ya how many rpm it drops, but it's enough to make the car shudder for a sec or two then jumps right back up....any ideas?
randeez is offline   Reply With Quote
Old 12-03-2011, 09:52 AM   #8
jerome
Toyota
12/1/11: 3,340 miles.
Average: 128 miles/wk (26 weeks)
Old 01-12-2012, 10:45 AM   #9
jerome
Toyota
1/1/12: 3,503 miles.
Average: 116 miles/wk (30 weeks)
Old 02-22-2012, 04:44 PM   #10
jerome
Toyota
Whoops. Forgot to check in for February.
2/1/12: 3,611 miles
Average: 103 miles/wk (35 weeks)
Old 04-12-2012, 09:32 AM   #11
randeez
Drives: 2008 3dr
5 months and 20,000 miles
just shy of 50,000 miles now, couple of syn oil changes, replacing air filter, changed plugs (no difference), still have a low idle stumble every once and a while. just rotated tires and checked brakes front/rear. finally got a ultragauge- the lack of gauges in the base model leaves mea bit worried. have it set up for instant mpg, average mpg, tach, water temp, voltage, and miles till empty- going to see if i can find oil pressure though
Old 04-12-2012, 12:22 PM   #12
Kal-El
Kal-El's Avatar
Wow, what's your commute like?
Old 03-15-2014, 03:20 PM   #13
randeez
Drives: 2008 3dr
been a little while, had to jump on and order some stuff from Garm(microimage)
brakes are getting a little noisy, passenger side pad, although still having more then 50% material left, looks like it has some stress cracking and pedal feel sucks - ordered new rotors and pads, going to flush all the fluid out as well
for future use:
11/5/11 @ 32,500 (purchased shortly before)
4/12/12 @ 50,000
3/15/14 @ 123,494
Old 03-31-2014, 10:51 AM   #14
randeez
Drives: 2008 3dr
for future use:
4/12/12 @ 50,000
3/15/14 @ 123,494
124,818 front pads/rotors and brake fluid
pads still had plenty of material, honestly think I could have gone 200k miles with oem pads- they were just breaking away from the steel backing maybe not broke in properly?
discs could have been reused/turned and reused for sure but I wasn't positive what was causing brake shake so I ordered some r1 rotors and hawk pads from micro image.
rear brakes I changed awhile ago, upon the advice of tire dick around 100k miles . I looked at them before and they didn't have much material... when he mentioned it I figured mileage had been plenty for oem to change anyway. Went ahead and ordered new ones, made the time to change em, pulled the drum off and realized they just don't have much material on them to begin with. But I had new shoes and the time to do it.
btw they quoted me almost 300bux to service rear brakes, so check em yourself they only have maybe 1/8"-3/16" of material
Old 10-23-2014, 12:23 AM   #15
randeez
Drives: 2008 3dr
for future use:
4/12/12 @ 50,000
3/15/14 @ 123,494
Jumped on to see if we needed to be worried bout airbag recall
I see a few more high mileage cars have come around
No issues since last check in, and I get the cup holder buzz, without the cabin filter I also get stuff down in the HVAC blower wheel too
10/23/14 @ 141,000
Old 11-05-2014, 03:29 PM   #16
camoang
Drives: 2007 Toyota Yaris
2007 Yaris Liftback
Blazing Blue Metallic
80,000 miles
2 new sets of tires (both Yokohama ~30,000 & ~60,000)
New brakes last summer (~60,000 miles)
Replaced driver window seal
Nothing other than routine oil changes, etc.
It has started running loud...a friend mentioned maybe the muffler might be bad. Hopefully it's nothing major.
camoang is offline   Reply With Quote
Old 12-03-2011, 10:19 AM   #17
bronsin
bronsin's Avatar
2009 3 door hatchback
black
27,000 miles
waterpump replaced ~26,000
cable rattle in reverse
Old 01-12-2012, 01:21 PM   #18
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
2008 LB
Blazing Blue
115 miles when bought
92,xxx
hvac control lites don't always wanna lite up but few hits then they do, just recently they been actin up. And my airbag lite is on from my first accident dunno y
2010 LB
Chrimson Red(Dark Red)
35,xxxx I think idk(mom's car)
no issues
Both brought brand new
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
excessive sulfur odor on 2007 model year Yaris tomjasz General Yaris / Vitz Discussion 121 03-13-2010 06:49 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
