![]() Drives: 2006 Yaris Join Date: Oct 2009
I have an 06 and just had to clean the sensors for the 2nd time last night. But the bad news is on the passenger side the plug fell completely apart. So I need to replace the ABS sensor wire (part 89516-52090) and the speed sensor (part 89544-52040).
Two questions; does anyone know a site that will ship to Canada and has the parts for a good price. The dealer cost is freaking crazy and more than double what i have found from sites in the US which won't send items north of the border. Second question, does anyone have DIY for changing the speed sensor? |
![]() you will need a press...at least that's how i removed my hub. i can maybe send it to you for 100$ shipped from US. Last edited by enviri; 03-02-2013 at 09:23 PM. |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
All I know is that when the dealer fixed my speed sensor issue (both left and right sides) it took them about 2-3 hours to complete the job. So it doesn't sound like it is a simple 10 min job.
![]() Drives: Yaris Hatchback LE Join Date: Jul 2007
owner of 2007 LB yaris, had rust proofing done when it was bought new from DVN dealership.
I just got this stupid ABS & (!) lights on problem about few weeks ago, after some googling i found this thread. I have a service appointment booked and will talk to them to see if they will do a good will pricing for me, if not, i'm not planning to fix it. |
jb48
Drives: 2008 hatchback automatic Join Date: Oct 2013
Now I have a dilemna!
I bought a used (97000 km) 2008 Yaris HB a month ago and it`s my sole everyday vehicle (my other one is a 1984 Suzuki 650 motorcycle). So far so good, no problem at all. In addition to everyday transportation, I use my car for delivering mail to mailboxes in rural area. I read all the 22 pages of this thread and now i have a dilemna: do I take preventive actions to address the potential problem by asking my mechanic to clean and grease the ABS connections when he`ll install my new winter tires or is it better to do nothing per popular proverb <if it ain`t broke, don`t fix it>? |
Take it apart and grease it with dielectric grease before it's too late.
![]() Drives: 2007 Yaris Join Date: Sep 2011
I've had the ABS & "!" light coming on intermittently since Christmas, and then it went solid for most of the winter so I suspected corrosion. Scan revealed C0210 (right rear speed sensor circuit).
Yesterday it was finally warm and dry enough to take a wheel off and have a look. Turns out that one of the two pin sockets on the harness was crusted up with green corrosion. And I can see why it happened, the plastic housing of the connector had a crack in it that let water in. Being as I'm a tightwad, I scraped out as much of the crust as possible with a small sewing pin and flushed out the debris with alcohol spray and compressed air. Added a tiny spot of grease in the hole and plugged it in. Cleared the codes by jumping the DLC and the warning lights are now off. I know this is a temporary repair, so the next time the light comes on I'm going to just replace both rear harnesses. |
![]() ![]() Drives: Hatch Join Date: May 2009
You're the best CTS! Will try to look closer.
Yes CTScott is the BEST!
D.
. CLA 250, 4MATIC |
And even better; I found a picture of releasing the clip from when we did the JDM Vitz RS rear axle swap on enviri's Yaris.
OK, I'm not sure I did it right, but I managed to get the connectors off to inspect them without damaging them. I'm still a little confused, though.
I have a service manual on CD, so I found instructions on page AH-14 -- "AXLE – REAR AXLE HUB AND BEARING" and there it provides the instructions: DISCONNECT SKID CONTROL SENSOR WIRE (w/ABS) I could not see any "claw" to remove; in fact I don't think there even is one. What I did is I followed CTScott's instruction (I think...) to remove that clip that you can raise up on top of the sensor with a screwdriver. Well, turns out it is sort of a clamshell like cover that surrounds the whole connector. In my photo below you can see that there is a slotted locking clip that snaps onto a little nub; actually there is one on top and on the bottom. To get the cover off you have to raise both clips and work the thing off. With the cover off I took a screwdriver and gingerly worked the connector off. It did finally kind of pop off. I did not find any broken pins or anything. Is that what I was supposed to do, CTScott? When concerns me is that the manual says "Do not remove the connector cover." Well, if by "connector cover" they mean that clamshell thing that surrounds the connector, that ship done sailed. I did not damage the wires, though, and managed to get it back on OK after reattaching the connector. When I had the connector off I checked it for that "claw" they said to remove. I did not find any separate part that I could have removed. That's what confuses me about this whole thing. Last edited by robkay; 08-25-2014 at 10:27 AM. |
#12 | |
They show to release the connector while it is inside of the cover. That may be possible to do if you can get into just the right position, but I find it much easier to remove the cover. As long as you are careful with the cover removal you will not hurt the wire.
So, is that thing they show to pry up in their picture actually a separate piece that you "remove" as they say, or do they mean to just pry it up to release it from a tooth or something? They give you the impression that there is like a clip that you actually pry out and remove. As I said, I looked at the connector carefully and it seemed like it was all one piece to me.
In any case, as you say, it would be pretty tough to get in a position to pry that thing up and pry the connector off at the same time. I agree, it's easier to remove that cover. The wires look delicate, but if you're careful and find any broken I would bet they were already corroded off. OK, thanks for all your input! (Old subject I know...) After doing the rear I find that my BRAKE and ABS lights are still on, so I guess I need to check the front now. Last edited by robkay; 08-25-2014 at 10:06 AM. |
#14 | |
Using this procedure you can find out which one is actually causing the error: http://www.yarisworld.com/forums/sho...&postcount=262
![]() Drives: 2007 yaris sedan Join Date: Mar 2010
Can anyone quote me roughly how much does it cost for parts total to replace both rear skid sensors and 2 sensor wires??
Im in canada but U.S. Prices okay just want to see how much... Thanks Sent from my iPhone using Tapatalk |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
You can't replace just the sensors. Only the wires.
Sensor is I'm the hub unfortunately ull need to replace hub bearing to fix sensor and harness
Sent from my XT1032 using Tapatalk |
The hub bearing replacement only fixes the sensor, not the harness.
