![]() ![]() Drives: Hatch Join Date: May 2009
So, is that thing they show to pry up in their picture actually a separate piece that you "remove" as they say, or do they mean to just pry it up to release it from a tooth or something? They give you the impression that there is like a clip that you actually pry out and remove. As I said, I looked at the connector carefully and it seemed like it was all one piece to me.
In any case, as you say, it would be pretty tough to get in a position to pry that thing up and pry the connector off at the same time. I agree, it's easier to remove that cover. The wires look delicate, but if you're careful and find any broken I would bet they were already corroded off. OK, thanks for all your input! (Old subject I know...) After doing the rear I find that my BRAKE and ABS lights are still on, so I guess I need to check the front now. Last edited by robkay; 08-25-2014 at 10:06 AM. |
