Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
Aftermarket Stereo / Speaker Specifications
TO Admins: Please Sticky this Post
I thought it would be a good idea to post + sticky this thread for quick reference for those who wish to install aftermarket stereos, speakers, and anything else that may come up as a FAQ. If there is any information that is incorrect, please feel free to correct me. Any additions are just as welcome so we can make this thread the ultimate reference for stereo info for the Yaris. Dash Kits - Single Din / ISO Mount Metra 99-8216 American International TOY K969 Dash Kits - Double Din / ISO Mount Metra 95-8202 Harnesses - Plugs Directly into Vehicle Plug (for aftermarket stereo) Metra 70-1761 Best Kit BHA1761 Scosche TA02B Speaker Sizes - Hatchback 3DR/5DR Front L+R 6.5" Rear L+R 5.25" Speaker Sizes - Sedan Front L+R 6.5" Rear L+R 6" x 9" Speaker Spacers/Brackets for Oversized Speakers (ie. Components, Midwoofers, etc) For those of you installing larger speakers with big magnets, you may want to use spacers to allow your speakers to be mounted to the door. I've created a template for the spacer for the hatchback speaker locations found here: http://www.yarisworld.com/forums/showthread.php?t=1930 At minimum you should use 1/2" MDF for appropriate clearance for the magnet when your window is completely down.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 Last edited by bigsky2; 07-31-2007 at 06:54 PM. |
Look mum no stars!!
Hey big sky
"Speaker Sizes - Hatchback 3DR/5DR Front L+R 6.5" Rear L+R 5.25" Do you know whats the best "Scosche" bracket / spacer to use onto the rear of the yaris liftback??? I was thinking of getting http://www.scosche.com/scosche_carau...48&ItemID=SAT6 cuz thats for the "2000-Up Toyota Echo / Avalon" |
Cousin Vitz
hasher,
I am afraid I do not have an answer for you. I have not replaced the front/rear speakers so I can't answer you! From what I've read, it's possible to use the existing bracket/spacer because the (stock) rear speaker size is a little larger than 5.25".
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
#4 | |
Look mum no stars!!
haha thats ok, i baught 6.5 inch speakers for the rear of my yaris.... but the stocked brackets are too small (the rear ones).....so i need to buy some brackets that will acually meet the holes so i can screw it in. (I dont wanna rivet it in) I baught MDF Wood 6.5 Inch speaker brackets.......the 6.5 inch speakers fit well on the MDF Wood brackets, but its not big enough to meet the 3 rivet holes in the rear. ARRG!! |
![]() ![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2006
this is a good idea to sticky this, wish i would have seen this before i went to the local shop today to get the dash kit.
i knew they wouldnt have it in stock, but figured they could order it, they check thier local distro. and didnt have any. so he got on the phone with Metra directly in florida, and they only said they had the Double din kit, i asked about a pouch/blank for it...but said it was just a double din...wish i would have jsut had the part number for them...gues ill have to go back there tomorrow and give it to them.... |
STICKY
![]() ![]() Drives: Yaris Sedan Join Date: Aug 2006
I want to get 6.5 rounds in the rear of my sadan....
So no solution yet? |
#8 | |
Look mum no stars!!
#9 | |
outside should fit the stock location, and the inside should fit your new speakers. but to fit "bigger" speakers in the location 6.5 > 6 you may need to do some cutting to the rear deck, or do some creative tapering on your MDF ring |
that will work, but it is likley for 5.5's, not 6.5's, i didnt see any specs on the inside hole...
From a physics standpoint, a 6.5" can be engineered to sound better than a 6x9 ever can.
sticky!
![]() Drives: 2007 Yaris 4D Sedan Join Date: Sep 2006
What is the difference between single din and double din for a head unit mounting kit?
Ok so I figured out the difference. If I obtain one of these kits, realistically, how hard is it to replace? Will I need any other parts? How long will it take for an amateur?
fairly easy to change out head unit, the hardist part is the wiring
just carefully match up all the wires on the harnes packaging, and in your aftermarket headunit manual. |
Look mum no stars!!
Warning - SAT6 SPACER/BRACKETS WILL NOT FIT INTO YOUR REAR LIFTBACK SPACE.
Thankyou :) How do i know? Cuz i tried.
#18 | |
Cousin Vitz
Well you hav spacer templates, so go make some!
| aftermarket stereo kit? | xCookiE | General Yaris / Vitz Discussion | 4 | 02-16-2006 10:33 PM |
