Old 03-23-2006, 11:43 AM   #1
wushumasterku
Drives: 06 White LE HB 5spd
down shifting and not coasting
Hi folks,
I have a question about driving manual. do you downshift all the time? or do you let you car coast to stop and use brakes when necessary?
i heard that the "modern" engines don't actually use any gas when you leave the car in gear. now is this same as downshifting (when they say leave it in gear?) but when you let your car coast in neutral, the engine actually uses some gas.
I'd like to hear your thoughts on this.
thanks
wushumasterku is offline   Reply With Quote
Old 03-23-2006, 12:13 PM   #2
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
good question, I am interested to know too as this will be my first manual car.
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Old 03-23-2006, 03:59 PM   #3
celica girl
Drives: '00 Celica, '07 Yaris
Personally I don't downshift unless I'm taking a corner. The way I see it brakes are cheaper to replace than a clutch. Unless you know how to rev-match properly when you downshift I say just pop it into newtral.
celica girl is offline   Reply With Quote
Old 03-23-2006, 05:52 PM   #4
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
Downshift all the way...If you downshift properly you're not going to wear out your clutch...
echo_hrs is offline   Reply With Quote
Old 03-23-2006, 06:05 PM   #5
Sp33dY
www.OZTOYOTA.com
Drives: Toyota Echo
I downshift 90% of the time ... Depends on what speed im slowing down from :) Sometimes go from 5th to 3rd to N, or 4th to 2nd to N, really dpeends on the road and conditions!
www.oztoyota.com - Australian Toyota ECHO and YARIS Club
Sp33dY is offline   Reply With Quote
Old 03-23-2006, 06:11 PM   #6
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Heel-toe'ing is half the fun of owning a manual, so you bet I downshift/rev-match.
As for the technical question, I would be very surprised if downshifting consumed less fuel, but I suppose it's possible.
Idjiit is offline   Reply With Quote
Old 03-23-2006, 06:52 PM   #7
celica girl
Exactly... that involves rev-matching. I'm not too good at that.
Old 03-23-2006, 06:56 PM   #8
SmellyTofu
好多人&
Drives: .
Yes all modern engines from the 90's to now run on no fuel when it's at a certain engine speed so yes, downshifting runs over (general rule of thumb is around 1500-1700rpm for petrol.. lower on diesel) will use less fuel than coasting down but you wouldn't use all that much at idle anyway. It also helps emissions in case anyone really cares.
SmellyTofu is offline   Reply With Quote
Old 03-23-2006, 07:04 PM   #9
Idjiit
5 Stars, Bitches
Err... But downshifting would mean higher revs if you're maintaining the same speed.
Old 03-23-2006, 08:01 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I use my brakes as little as possible, but I don't make the engine brake any more either, as that uses fuel. I just disengage the clutch and coast to a stop.
Old 03-23-2006, 09:28 PM   #11
SmellyTofu
好多人&
Drives: .
Your wheels run the engine when you're going down a hill in a lower gear (rather the other way around when you're accelerating). Engine speed doesn't mean you're using more fuel.
Out of interest, drive a car with a instantaneous fuel consumption gauge. You'll find idling at say 80km/h down a hill, you'll be using <0.5L/100km but when you're using engine braking, you'll be using 0.0L/100km.
Old 06-10-2006, 06:40 AM   #12
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
This is an EXTREMELY interesting topic..i've been wondering about this for many years. I love rev-matching on both up and down shifts, and I pretty much coast to slow down for stop lights. but, it would be really cool to use a measuring device to check actual fuel consumption (like in many 90's BMWs)..
TRD_Yaris is offline   Reply With Quote
Old 06-10-2006, 09:59 AM   #13
boxerboy
Drives: WRX ,Tacoma and Yaris
When the engine is running it is burning gas. I have yet to wear out a clutch in any car. My highest mileage was 108,000 on a toyota tercel mostly city in Dallas. I was a service rep. Any way I almost always downshift, so if the light changes or the traffic starts to move I will be in the right gear to keep moving. When I see that the light has just turn red or traffic is not moving I will just brake. Of course that depends on the speed. I will downshift a higher speeds and not at low speeds.
boxerboy is offline   Reply With Quote
Old 06-10-2006, 11:38 AM   #14
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
I used to drive big rigs when I was in my early 20's and always used the engine/gears to slow down, although the yaris doesn't weigh anywhere near a semi so you can't compare the two :) But, its less wear on the brakes and like what boxerboy said you are ready to go if traffic starts moving. If I know that traffic isn't going to move then I would put it in neutral the last 100 ft and use the brakes to stop.
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 06-10-2006, 11:51 AM   #15
Master2192
Drives: 98 Subaru Impreza 2.5RS
When you are engine braking, the ECU turns off the injectors until the rpms get down to a certain value (~1500). This is very easy to see on a AFR Gauge or a scanner showing Injector duty cycle.
I rev-match downshift all the time, and it doesn't add anymore wear to my clutch and my brakes last 2x as long. I believe it is a skill that all manual drivers should learn. It is definitely an advantage to be already in gear if you need to start accelerating again.
Master2192 is offline   Reply With Quote
Old 06-10-2006, 12:10 PM   #16
ricko
ricko's Avatar
Drives: Copper-Orange Yaris RS
This is a great thread. I had no idea that ECU technology was that "smart"!
Although the original question was in reference to coming to a complete stop, my comment relates to the car's behaviour while cornering. Downshifting and keeping the power on (even very moderately) has the advantage of keeping the suspension under load, which improves the car's ability to make the turn. It is safer to drive around a corner than it is to coast around. The process is: brake to reduce speed, downshift, and drive through the corner (the more skilled can do this all at once). This SEEMS to be especially true for front-wheel drive vehicles, although I have no concrete evidence to back this up. Maybe someone can explain the physics of cornering and braking in better terms for us.
ricko is offline   Reply With Quote
Old 06-10-2006, 02:44 PM   #17
plushDJ
Drives: 2007 3 dr manual
I'll downshift from 4th to 2nd but that's about it
plushDJ is offline   Reply With Quote
Old 06-11-2006, 01:42 AM   #18
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Bad news, the yaris doesn't "en-lean" when engine breaking. All the GMs i'v owned you could really feel it kick the fuel flow down when engine breaking. My aurora you could see then MPG increase when engine breaking, it auctually got less MPG when in neutral vs drive for coasting.
My scan gauge shows 0.2 Gallons Per Hour when costing in neutral for the Yaris. I did some engine breaking in 2nd and it was around 0.5 GPH. Also when you feel that slight engine break when coasting (you can slightly feel it kick in and out on my auto) is putting the PCM into open loop for a couple of seconds and the GPH is the same as in neutral. Also coasting it reads about 200-250 MPG and when downshifting it drops to 60-100.
I dont think there's a need for the yaris to enlean tho. I just did a trouble code test on a chicks car at work and her 2000 or so neon 4 banger showed 0.6 GPH at idle. I cant imagine what my aurora was at at idle. So thats round 5 hours for the car to idle out a gallon of gas. and 2 days to idle out a tank, not too shabby :)
So coasting in neutral is the best way in the yaris for MPG. BTW full throttle is around 6-7 GPH and normal driving is 1-3 ish and idle w/ the AC on is 0.3 and auctually shutting the car off while long coasting can add 1 or 2 MPG as long as its done on a normal basis. I have an auto so it kinda sucks to crank the starter 50 times a day. Just think of them as free miles that dotn cost you $$$ :)
pennystocks is offline   Reply With Quote
