#109 |
![]() Drives: 2007 Yaris Hatchback Join Date: Feb 2009
Add me to the list. I have a 2007 Hatchback, and I also am discouraged about the ABS and ! lights. My car's ABS activates on pavement and I have had to get someone from the dealership to look at my car twice now. Does anyone know if the problem fixes itself once the new parts are replaced in the car ? I'm from Halifax, but I see the majority of cases seem to be in Ontario.
#110 |
In between cities
Drives: 2006 yaris ce Join Date: Feb 2006
i wonder if this problem is just a north american problem? If anyone from northern europe is viewing this thread and are not getting the same problem. Maybe we can get the sensors from europe since there better made for the cold weather. Just an idea.
#111 |
Well, they fixed my left rear sensor and now the right rear sensor is posing a problem. They ordered the part for me this morning and I am hoping that once that comes in and is put in, that the problem will be solved. I'm just happy both sides are getting fixed at the same time. At least I am not driving the car around with two faulty sensors !
#112 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Oct 2008
Has anyone who's had this problem (while still under warranty) ever demanded the dealer fix all four at the same time? It doesn't seem like an unreasonable request, being all four wheels are exposed to more-or-less the same conditions and would have nearly the same amount of wear and corrosion.
#113 | |
MORDSITH
Drives: 2007 Yaris Hatchback Join Date: Apr 2006
Anyways, i bet if i ask, they'll just tell me they simply cant or wont unless it becomes a problem with an error msg.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic |
#114 | |
Car crazy
Drives: 06 Yaris RS 06 CR-V Join Date: Jan 2009
I asked if they can replace them all as well - no dice - TCI won't cover it. While it's in they'll remove the sound deadening for the recall... apparently they just remove the foam in the pillar - not replace it... My satisfaction is not what it once was.
#115 |
MORDSITH
Update... there was a message from Toyota saying my part was in...
Guess that means *finally* that ABS harness has arrived!? Ill let you know once I call them back tomorrow. Man, but that was a serious backorder... ,,,
#116 |
![]() Drives: 2008 RS, 5spd Join Date: Nov 2008
I've been waiting for over a month, hopefully not much longer now...
#117 |
![]() Drives: 2007 Yaris Sedan (Aero) Join Date: Jan 2009
My car goes in Friday. They're going to do the ABS sensor and the recall.
#118 | |
MORDSITH
Set up appt w/ Steve for Monday to finally deal w/ this issue.
#119 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Just curious how much it costs to get one of these sensors replaced. I know one or more of mine are dead ... just want to know what I'm looking at in terms of $$.
#120 |
![]() ![]() Drives: 1997 Yaris LE Join Date: Jan 2009
Well I finally have an appointment this Tuesday to get the part replaced. One thing that pisses me off (besides the intolerable wait, of course) is that I asked the guy if a 2:00 appointment really means I'll get in at close to 2:00. His reply was something like, "well we can't guarantee the times because we might get backed up from the morning". Excuse me, but WTF is an appointment system for? When you book the appointments, you obviously have an idea how long each job will take. I hope this recession lingers on so that these retailers will feel a tight pinch and change their tune and actually value a customer.
#121 | ||
MORDSITH
Then they call me when its all done in the afternoon and they send someone out to pick me up again and bring me back to the dealership so i can get my car. i never wait in the dealership for them to do these things.
#122 |
#123 |
Did anybody ever experience their abs going off on dry pavement ?
#124 |
Well I had mine fixed today and it would have cost $480.00 if it hadn't been covered under warranty.
I spoke to the mechanic and he told me the part wasn't corroded. The part in question was a "manufacturer defect". Which makes me wonder why Toyota hasn't issued a recall. |
#125 |
MORDSITH
So she's all fixed now. Got it *finally* looked after on Monday.
The official 'cause' as listed on my repair invoice is: "Right rear speed sensor harness" And interestingly enough, apparently there's a TSB out for this!?!? (What does that mean exactly then???) Because the 'correction' on my repair invoice reads: "Labour to diagnose and replace speed sensor harness as per TSB3027" (Part # was 89516-52090, and description was "Wire,Sensor" in case anyone was interested) There's my update ppl.
#126 | |
