Old 09-24-2006, 10:03 PM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Spacer Template for Hatchback Aftermarket Speaker Install
Hey guys,
I took some time this weekend to get some measurements of the speaker brackets for the hatchback (mine's a five door) as I will begin a complete overhaul of the audio components.
As others have mentioned, the stock speaker is actually the bracket for the speaker. Therefore if you remove the stock speaker, you will need a bracket to mount your aftermarket speaker.
I opted to use custom spacers because I want as little air as possible between the metal, bracket/spacer, and the speaker's chassis. Air = shitty sound reproduction.
This is a template for the Front and Rear door speakers.
Instructions as follows:
1) Print out the template
2) Find out the MOUNTING DIAMETER of your aftermarket speaker
3) Draw the mounting diameter of your aftermarket speaker using the centre (X) as the point of ref. I strongly suggest using a protractor
4) Cut the template along the outside edge carefully
5) Cut out the inside circle that you drew in Step 3) carefully
6) Voila, you now have a template to use on MDF, High grade plywood, or any other material you wish to use.
Notes: Depending on your aftermarket speaker, I would suggest using 1/2" thick MDF as the material for your custom spacer. 1/2" gives clearance to larger components.
Enjoy and good luck!
PS - If you wish to reuse the stock speaker bracket, you have to carefully and cleanly remove the speaker component from the bracket. This will pretty much destroy and render the stock speaker useless.
If anyone is familiar with CorelDraw, you are more than welcome to PM me for the CDR file which will allow you to draw a precise and exact circle.
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Aftermarket Stereo / Speaker Specifications bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 93 10-20-2022 03:38 PM
DIY 07 Sedan Rear Speaker install vodkalush DIY / Maintenance / Service 32 10-20-2017 03:40 PM
door speaker install gone wrong!!! punch In Car Entertainment + Electronics (audio / video / alarm) 17 06-28-2006 01:49 PM
