Old 05-15-2009, 11:58 PM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
expo2, no you do not put the clutch switch in series with the cruise circuit. In fact you put it in series instead of the jumper wire stated on page 21 of this "DIY" HERE
See my post...#371.
Instead of placing the jumper wire in those two slots (as shown in the pics), simply go from one slot to the clutch switch, then back to the other slot.
Try to picture your clutch switch in place of my fuse in the pictures.
I will be making my own clutch switch tomorrow and I will take plenty of pics.
Hope this helps :)
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-16-2009, 11:28 AM   #2
expo2
Drives: 2008 Yaris HB
Dah, I feel like an idiot and then some. I don't know how I missed your original pics of the clutch switch jumper wires.
Thanks for your help.
expo2 is offline   Reply With Quote
Old 05-16-2009, 12:31 PM   #3
nickhjort
nickhjort's Avatar
No problem. Glad to help :) I will be starting my custom clutch switch here shortly. I have to go find a switch. Then I'll post pictures later this evening.
My Car Rules!
Old 05-16-2009, 05:36 PM   #4
nickhjort
nickhjort's Avatar
See post #387 HERE
My Car Rules!
Old 05-18-2009, 01:56 AM   #5
PatrickJohnson
Drives: 2008 Yaris LB
This is the only mod I've ever done that involved the ECM, can someone kindly enlighten me as to it's location? I believe it is in the engine compartment, right?
PatrickJohnson is offline   Reply With Quote
Old 05-18-2009, 03:37 PM   #6
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Exactly - it's on the right side of the engine compartment.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 05-18-2009, 05:56 PM   #7
PatrickJohnson
pardon my ignorance, do you mean right as in while you are in the car or right as though you are facing the engine compartment while standing at the front of the car?
Old 05-18-2009, 06:38 PM   #8
MGargano
Drives: 2009 Yaris Hatchback
Driver's side
MGargano is offline   Reply With Quote
Old 05-18-2009, 09:36 PM   #9
Sir A.Y. Atoyot
Drives: '08 5-door
Right side of the car as you sit in the driver's seat - the passenger side, in other words.
Old 05-18-2009, 11:57 PM   #10
nickhjort
nickhjort's Avatar
Passenger's side in the engine bay. Also my clutch switch works perfectly. It truly is a frankenstein though. I will take some pics tomorrow when it's light outside. If you don't mind spending the 18 bucks, buy the stock one. It will look more professional. I may switch it out later, I just wnated to see if I could make my own :)
My Car Rules!
Old 05-19-2009, 12:51 PM   #11
PatrickJohnson
Excellent, I'll give this a shot this weekend and report back results.
Old 05-19-2009, 09:55 PM   #12
PatrickJohnson
okay, i gave it a shot with no luck. I wired the switch as shown with the correct resistor values, and went to run a wire to the ecm. THat's where i hit a snag...
I thought there would be an existing wire for me to tap to. instead, i have one of those little harness plugs in the hole where pin 40 would be. how did you guys install the wire? I'm itching to do this!
Old 05-19-2009, 10:02 PM   #13
Check out this other thread, starting at page 16 to see how nickjhort did it:
http://www.yarisworld.com/forums/sho...=16188&page=16
Old 05-19-2009, 10:43 PM   #14
PatrickJohnson
AAAARRRRGGGHHH!
So, i finally got a few strands of the "red" wire pulled through the ecm connector on pin 40, so i know there is a connection. the black side is grounded directly to the black battery cable.
my switches are wired exactly like described (2 switch method).
i'm going to check my resistor values, maybe i used 620K instead of 620 ohm.
Old 05-19-2009, 11:23 PM   #15
PatrickJohnson
SUCCESS!!!!
Turns out I had grabbed the wrong resistors. Once i corrected it, I road tested and it worked like a charm. I've drilled holes and mounted the switches, but I'll have to wait until this weekend to run a permanent wire from the ecm.
So, I can confirm 100% that it works on a base model auto trans 2008 LB.
Old 05-20-2009, 07:37 AM   #16
SUCCESS!!!!
Great!
We should try to figure out a terminal that will fit the pin on the ECU, so that a more proper connection can be made. The next time I place a Digikey order, I am going to order a bunch of different sizes of Molex connector pins and try to find one that fits well.
Old 05-20-2009, 10:14 AM   #17
PatrickJohnson
also, you can make a pretty secure connection by doing it the way nickjhort pushed it through the connector, only instead of just fraying the wires a bit, you can push it through enough to wrap the wire up into the large slot in the middle of the connector. This will secure it in place and make sure it doesn't pull out.
Old 05-21-2009, 01:10 AM   #18
PatrickJohnson
some pics of my install. it's all permanent and looking good!
New wire added:
Came through the firewall at the rubber hose on the passenger floor board
wiring at the switch point
Convenient grounding bolt under passenger kick panel
Finished!
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
