Old 05-01-2009, 07:58 PM   #19
Meteorite_Marty
It's not that hard, I had a little problems understanding mine but in the end I figured it out. The biggest concern was pulling a weeks-old car apart, but I got it back together for the most part. There are great instructions on here and the bits that are different are easy to figure out.
I am contemplating HIDs, but I think I would like to eventually go for some new headlights as well so I figure I might as well do both at the same time. Money is the biggest constraint at the moment, but I'll save up and will convert the headlights on my 08 HB in the near future once I figure out what I want to do...
Cheers! M2
Its not a "factory" install, the way you did it. I don't want to void my warranty, so I did it all as per the Toyota instructions.
Old 05-01-2009, 08:00 PM   #20
Meteorite_Marty
Originally Posted by DerFlosser View Post
To really make it easy on yourself, do as Marty states and purchase the foglight integrated headlight stalk. It makes this job a walk in the park. If you can hold on a few more days, I will do a write-up on the install. All you'll need to do is buy the kit from Garm and source the foglight integrated headlight stalk. If you have an 09 you will need the bezels for the bumper as they are different from the early cars. I am assuming that the hardest part of the whole install will be installing the stalk but I will do the write-up and hopefully it will help somebody.
Stalk is not too bad to remove. You will need torque screw driver bits to remove the steering wheel housing. Then of course you have to take the steering wheel off after that. My steering wheel was tight, and took a bit of force. Again, follow Toyota instructions for removing a steering wheel and you will be golden.
Old 05-01-2009, 10:55 PM   #21
uncleyaris
I think I'll hire Marty for anything I need installed!!!! You da MAn.
Old 05-01-2009, 11:01 PM   #22
TitaniumBarbell
TitaniumBarbell's Avatar
Drives: Yaris 3Dr LiftBLACK
Toyota fog lights dealer installation: $75.00 with me.
TitaniumBarbell is offline   Reply With Quote
Old 05-02-2009, 12:23 AM   #23
Meteorite_Marty
Nothing against Puerto Rico, but how much is labor there for a mechanic. Here (Canada) its $75 to $100 an hour.
Old 05-02-2009, 12:25 AM   #24
Meteorite_Marty
Originally Posted by Phaeton View Post
Where do you buy the turn factory foglight turn signal stalk?
Here's the link to buy the stalk. Took me 2-seconds to find in the forums.
http://www.trademotion.com/partlocat...07&catalogid=2
Old 05-02-2009, 10:46 PM   #25
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Here is the link for TRD Spark's same price but a vendor here
http://www.trademotion.com/partlocat...&siteid=214631
Old 05-02-2009, 11:52 PM   #26
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I installed everything today so that, when I get the stalk, it's the last thing to do. Everything was very straightforward to this point. I just have to install the stalk and I will be in business.
DerFlosser is offline   Reply With Quote
Old 05-05-2009, 10:19 AM   #27
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Ok,
So...this a.m. I installed the new stalk before I went to work and it was surprising simple. It took me about 30 minutes as a first timer being extra vigilant of things. If I had to do it again....it'd take about 5 minutes. Anyhow, the fog lights are/were already hooked up and ready to go and the car came pre-equipped with the fuse in place. So, I installed stalk 84140-52151 and turned the lights on......golden. Everything works EXCEPT for the fog lights!!!! No lights and no indicator in the instrument panel. I have no idea why they are not on as everything is wired correctly. The only variable is the fact that I have my DRL's disabled but I don't think that this should cause a problem but I cannot say for sure. Any help or insight from somebody with experience would be great, thanks!
Old 05-05-2009, 11:13 AM   #28
omendt
omendt's Avatar
Drives: 2008 Yaris Liftback
Has anyone installed these foglights and used the rocker switch instead of the stalk replacement method? I see that it is easier to go with the stalk, but I am curious as to how much more difficult it is with the switch (I like the idea of having the switch to the side for some reason).
Coming up on owning my Yaris for a year and wanted to post for the first time after reading all the great threads. I am going to be buying the MicroImage Foglight set next week.
Thank you in advance for the insight!
omendt is offline   Reply With Quote
Old 05-05-2009, 02:11 PM   #29
TitaniumBarbell
$80.00 - 150.00, depends if you go to the city or town.
Old 05-05-2009, 08:51 PM   #30
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Put the DRL module back in and it works like a gem. Thanks to CTScott for tipping me off! I love the fact that the fogs are a twist of the fingers and the cluster indicates they are on.....OEM is the way to go with this mod.
Old 05-12-2009, 05:35 PM   #31
omendt
omendt's Avatar
Micro Image Fog Lights
I was about to pull the trigger and pick up the Micro Image Fog Light kit, but wanted to see what was the level of expertise needed to install them into a 2008 Yaris Liftback?
Thanks in advance for anyone's opinion!
Old 05-12-2009, 05:38 PM   #32
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i used rocker switch and never looked back......
Old 05-24-2009, 07:56 PM   #33
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
my dealer charges 65$ an hour and they said it takes 2hours to install them...65$ x 2 = 130$ plus the kit 99$ (not from theme off course) 230$.. And they sell the whole kit installed for 500$..and taxes are not inclued in prices...
the_boss is offline   Reply With Quote
Old 05-24-2009, 08:05 PM   #34
MadMax
MadMax's Avatar
It is easily doable with standard tools. My car was just a few weeks old when I did mine, and tearing off the front bumper and all the area around the wiper blades is discerning, but it definitely doable.
Cheers! M2
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 02:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-03-2006 12:38 AM
