![]() ![]() Drives: 2007 Yaris Join Date: Jun 2006
What kind of LED's did you order? I have done a lot of work with LED's before, so I can't wait to get started on this lil project.
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
well I was gonna go with the full DIY and get some leds from radioshack and resistors... but its much easier and cheaper (as single super bright LEDs white or blue where about $5 a piece) so I got mine from*http://autolumination.com/74.htm (from a link in either this thread or a diff one... cant remember and dont care to look
) they where "Neo - Wedge Instrument Panel Bulbs" leds.
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
#3 | |
I drive a yarrrris
Look mum no stars!!
I got 3 spare light bulbs if anyone wants them, the ones i used in my tutorial. Though u only have to pay for shipping....
It would prob. be cheaper to buy the bulbs urself... :)
Well I just got myself some little red condoms yesterday, time to go yank out those console panels
Done!
Thanks Hasher22, the pen was certainly a very useful tool for this ![]() Also, word of advice, don't do any car mods in the middle of a hot, sunny day, I'm drenched with sweat now
Look mum no stars!!
YAY!!! PICS!!!????
ta-daah!
![]() Would these be a direct drop in? If not, which neo wedge bulbs should i order from that auto-illumination site? |
#10 | |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
they won't be very bright at all though i did the interior on my last car using them little colored lights and eventually switched to LED because the colored bulbs were to dim
The early bird gets the worm, but the second mouse gets the cheese. |
I drive a yarrrris
yup those will work
I ordered one of these for the shifter.
![]() And 3 of these for the knobs. ![]() This all work out okay? |
Ya, i saw that I had linked to those bulbs, so i switched, and ordered the LEDs. I hope they will work out.
LEDs would certainly give a much brighter result, but I'm pretty happy with the way it turned out on mine :)
After receiving my LED's a while ago, I just now got around to installing them. I was worried that I was going to have to remove the bulbs and swap them into the existing black plastic pieces... but the ones I ordered required none of that at all. The process actually went a lot smoother than I expected.
I did run into one problem however... I wanted to change the bulb in the shifter of my Automatic, but I couldn't find a way to get that small piece of plastic on the top off. I removed the cover to manually release the shifter, but that got me nowhere. Can anyone guide me to changing this bulb? Here is a pic I took of the knobs after installation. Sorry for the quality, but its a phone cam in the dark. |
I drive a yarrrris
its a beotch to remove that center piece... there are 4 snap points that hold it down (us a flathead to release the hold points) then lift and go either forward or backward with the newly loose and lift; taking it out is actaully easy, its putting it backin thats a bitch... but you really just do that opisite of what you did to remove it
hope this helps edit: White Power!!
Are you talking about the small center piece with the P-R-N-D-3-2-L letters on it? Are the hold points straight down the sides? Is there any way to remove them without gouging the crap outta the plastic?
I drive a yarrrris
yah, dont jab the the plastic... there are only 4 tabs one just inside on each corner on the "long sides." you pop the tabs and pull up alittle
| Accessory Bulb Types, anyone know? | Ayka | Cosmetic Modifications (Exterior/Interior) | 135 | 04-29-2007 08:33 AM |
