Old 06-04-2009, 01:47 AM   #1
YarisFan007
YarisFan007's Avatar
Drives: 2007 Toyota Yaris HB
Green means go?
Hello fellow Yaris friends,
I have a few questions- After starting your engine do you guys wait until the temperature light goes away before you head out?.. Or do you disregard the light and just go anyways? Is it a bad thing to start driving after you fire up your engine without warming it up first?
Almost every time I start mine, I wait until the engine is fully warmed up and the temperature light goes away. I can recall maybe only 2 or 3 times I didn't wait for the light to go away because I was running late for something. But ever since the day I bought my Yaris I've tried to treat her well.
Just curious to know if everyone warms up their engines as well.
YarisFan007 is offline   Reply With Quote
Old 06-04-2009, 01:55 AM   #2
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
It's fine to drive it while engine is still cool. Just be easy. My old S2000 set the rev limiter to 6000 rpm until it warmed up, just a random fyi hehe.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 06-04-2009, 02:22 AM   #3
texkid
The one with cheese on it
Drives: '10 Corolla S
Yeah, just take it easy while Cool light is on. I personally wait about 2 minutes or so and then head on out.
texkid is offline   Reply With Quote
Old 06-04-2009, 03:09 AM   #4
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
I think the Honda fit is actually go.
mr9865 is offline   Reply With Quote
Old 06-04-2009, 07:41 AM   #5
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drive
I would just drive gently until the car warms up. This is better for the car because it will warm up faster and better for your wallet.
The exception might be extreme cold starts, well below 0 F. Then I might let it idle a minute or two, depending on how the car acted.
The AT locks out 4th until the cold temp light goes out, apparently to facilitate a faster warm up.
Old 06-04-2009, 10:09 AM   #6
SailDesign
Drives: .
Just think of all the gas you use sitting in the driveway. Turn the key and go, but be gentle until the light goes out.
Old 06-04-2009, 10:44 AM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
One of the hardest things you can do to an engine is to let it sit idling till it warms up. That builds up all kinds of sludgy glop and often leads to piston ring sticking. Many cars you see trailing blue clouds of smoke do so because people start them up and let them warm up before they drive away. Not to mention that idling wastes lots of fuel at exactly zero miles per gallon and puts out more air pollution than driving to warm up. As said above, it's best to crank it up and drive away, just being moderate in your driving till it warms up.
Old 06-04-2009, 11:24 AM   #8
nerp
Drives: 2009 3dr LB Meteorite Metallic
You're doing it the wrong way. Sitting and waiting for the light to go away makes the point in which most wear occurs last longer than it should. The ideal scenario is you start the car and drive off immediatley, making sure not to gun the engine until the light goes away. This will reduce wear (since the engine warms up faster). Just the time it takes for you to attach your seatbelt and turn on the radio is enough for the oil to pump through, even in the dead of winter.
nerp is offline   Reply With Quote
Old 06-04-2009, 11:51 AM   #9
YarisSedan
Drives: 08 Yaris Sedan
You will also notice if you drive a automatic the the transmission holds the shifts longer instead of upshifting at a lower rpm in order to speed up the warm up process faster. Once its warmed up it goes back to normal economy shifting mode.
Old 06-04-2009, 11:59 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
you are supposed to hold it to 3000rpm until the engine is warmed up. Obviously, drive it...
In the summer is start and go. Winter? Start, 1min and go. I was driving a Pontiac G5 coupe when it first came out.. it had a digital oil temp reading. I noticed that as soon as i start the car and press the button to see the temp, it was already above freezing point, even at -40c outside.
Old 06-04-2009, 12:01 PM   #11
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Damn Right!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 06-04-2009, 12:45 PM   #12
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
The 'cool' light on my car goes out within about 2 minutes. I start up and pull out within about a minute at the most and the light is out by the time I get to the end of the block.
Just be easy on it until the light goes out and you're golden. The car's just making sure you know how cool it is to have you behind the wheel.
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 06-04-2009, 01:52 PM   #13
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
Ha. :p
Old 06-04-2009, 03:01 PM   #14
paraganek
paraganek's Avatar
Drives: 2008 Yaris Liftback 5 speed
Send a message via ICQ to paraganek
Absolutely agree. The most important is to warm up the engine fast and you do that by driving instead of idling.
paraganek is offline   Reply With Quote
Old 06-04-2009, 11:31 PM   #15
The little red pill
Taking care of Bubbles
Drives: 2009 Yaris LB "Bubbles"
I usually just redline it till the cool light goes out. It seems to warm up pretty quick that way.
2009 Absolutely Red LB. "Bubbles"
The little red pill is offline   Reply With Quote
Old 06-04-2009, 11:37 PM   #16
IllusionX
ha.. been through that route... did that all the time with the company van..
it has some 80000+km now.. still not taking a drip of oil lol
Old 06-05-2009, 08:25 PM   #17
Yaris Hilton
Smile
As long as the engine's got oil pressure established, the hazards of "flogging" a cold engine aren't really much if any worse than doing the same with a warm one. Deposit buildup is the big problem with slow warmups.
Old 06-05-2009, 09:42 PM   #18
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
Originally Posted by YarisFan007 View Post
Or do you disregard the light and just go anyways? Is it a bad thing to start driving after you fire up your engine without warming it up first.
I got lucky... when I bought my Yaris they gave me this really cool book with lots of pictures telling me all about the car!
(I know, I'm evil)
twowheels is offline   Reply With Quote
Corolla means Proven, Yaris means ? Yawesh General Yaris / Vitz Discussion 9 02-05-2009 01:07 PM
FS: Used 4gb Ipod Nano Green $60 shipped contraband831 Items for Sale by private party 5 01-08-2009 05:32 PM
Green ECO plates for Ontario, still planned? MUSKOKA800 Canada 4 10-29-2008 01:29 PM
Dark Green Yaris ~ jaspie Australia 9 03-30-2007 11:34 AM
Yellow, Purple, Green Headlight BULBS? jamal1984 Cosmetic Modifications (Exterior/Interior) 12 02-04-2007 09:30 AM
