Old 06-21-2009, 01:03 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
Too bad you arent in North Florida, Savannah GA would be a quick trip up!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-21-2009, 01:51 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Just watched the 3rd video. Yup, definitely faster. The segment that was taking 11-12 seconds on the other vids was down to 10 seconds. Which just shows that you're hitting one of the fundamental problems of trying to tune a suspension while you're still learning the finer points of autox/track driving. Stop me if you've heard this one before... "tune the driver first!"
You've just made more actual difference in your cornering ability by merely changing your driving technique a little bit than you did with all of the new mods that you did! I'm not saying don't mod the suspension, especially since you're so far along, anyway... but do find a point where it's "good enough" (have an experienced FWD autocrosser flog it and get their opinion) and just leave it alone while you learn to drive it.
I mentioned hand position above... look how your left hand is at the top of the wheel, often crossing 12:00 throughout the turn. Your right hand is doing the same thing at the bottom. Teach yourself to "shuffle steer" so that you're anticipating the turn and pre-positioning your hands so that in the middle of a big sweeping turn like that, they are at about 9 and 3. You'll have WAY better control that way. You'll be able to make smoother and more subtle corrections because you'll be turning the wheel using your arm muscles instead of your shoulder muscles.
You should make a road trip over this way for one of the Tampa area autocrosses sometime... or maybe we can get together for an event at Sebring. I'm a member of SAFE Motorsports, we could share an entry at one of their events.
Old 06-21-2009, 01:56 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
i'd like that. i definitely have more work to go on the car (fix the destroyed engine next) i'll try shuffle steering next time i'm out there. i will also be lowering the car 2" as soon as the springs show up (the car is higher than stock in the front right now) so this may or may not help. we'll see! i also haven't aligned the car since yesterday. not sure it'd matter but after the 4" springs show up i'll go and align it again.
Old 07-25-2010, 10:20 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Bump :) I wanna read the rest of this thread later.......
the angry panda gets angrier... Tamago Off-topic / Other Cars / Everything else Discussions 11 12-09-2008 12:43 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
