Old 07-23-2009, 11:33 AM   #55
saplaymate
saplaymate's Avatar
Drives: 08' HB
the Blitz is not a Roots (eaton) type SC, just for clarification.
Tru Tru both suck
0 - 60 in 3 shifts
saplaymate is offline
Old 07-23-2009, 11:47 AM   #56
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by saplaymate View Post
Tru Tru both suck
do you need me to post the dyno flow charts? the twin screw makes its power sooner than your centrifugal. which is important for a car that only revs to 6500rpm..
and either way, turbo>lysholm/centrifugal
GLWS
Tamago is offline
Old 07-23-2009, 12:09 PM   #57
saplaymate
saplaymate's Avatar
Drives: 08' HB
post away. What are people pulling on a dynojet with the Blitz 117-120? @ 8 psi whoa!
You could always start your own informational thread if you wanted too.
0 - 60 in 3 shifts
Old 07-23-2009, 10:31 PM   #58
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
well mine made 133whp on my first pull; then i had to stop because of my AFR was lean. However, I have larger injectors now, along with a 1zz throttle body. I'm sure it'll get higher numbers next time.
how's that pending sale going?
PETERPOOP is offline
Old 07-24-2009, 01:11 AM   #59
saplaymate
saplaymate's Avatar
Drives: 08' HB
Were your 1ZZ injectors light blue with 12 holes? Yeah could say your car was running lean i saw your dyno, you should dyno it again soon to see if it's better instead of just assuming.
And good thanks for asking.
0 - 60 in 3 shifts
Old 07-24-2009, 01:16 AM   #60
PETERPOOP
PETERPOOP's Avatar
That's what my wideband is for? Thanks for looking out for me! lmao
Old 07-24-2009, 02:41 AM   #61
saplaymate
saplaymate's Avatar
Drives: 08' HB
your wideband can verify hp awesome!
0 - 60 in 3 shifts
Old 07-24-2009, 02:48 AM   #62
PETERPOOP
PETERPOOP's Avatar
good way to try and cover your butt. lmao. we all know you were implying the lean condition. that's cool. GLWS
Old 07-24-2009, 03:18 AM   #63
saplaymate
saplaymate's Avatar
Drives: 08' HB
Your right that is what it sounds like I meant when I read it now too. I should have used a period.
On that note though, I brought a set of 1zz injectors to check out, they were light blue with 12 holes and flowed the same as our stock light blue 12 hole ones. I was sad because I hoped they would flow more. Mine came from a Celica? I actually at one time posted the flow rates of oem Toyota injectors one this forum too
0 - 60 in 3 shifts
Old 07-24-2009, 03:22 AM   #64
PETERPOOP
PETERPOOP's Avatar
I bought them used from ebay. I'm not sure how many holes they had. However, my numbers on my wideband dropped by one point once the 1zz injectors were installed. Went from 12.5 at WOT open loop, to now 11.3-4 at WOT open loop.
Old 08-08-2009, 03:51 PM   #65
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Did this thing ever sell? Bump it.
Galavoxx is offline
Old 08-18-2009, 01:57 AM   #66
AdeJong 03
"Stealth Runner"
AdeJong 03's Avatar
Drives: 2009 Yaris-S Sedan
also curious
AdeJong 03 is offline
Old 08-18-2009, 02:02 AM   #67
I think someone did buy it.
Kaotic Lazagna is offline
Old 08-18-2009, 02:03 AM   #68
Originally Posted by JBIZZ View Post
Bought saplaymate's Rotrex kit.
As of right now the boost is set low. I am waiting to install some gauges before fine tuning it. I paid a buddy $350 to install and reprogram the computer. I am planning on getting a custom 3-stage ceramic clutch made & possibly a stoker kit from Japan & LSD.
I am running the 1zz throttle body & was advised to get a magnetic actuator for it from a Celica to offset response delay.
I blew the stock belt 1st time driving it & still need different spark plugs.
Yes, it was bought.
Old 08-18-2009, 02:24 AM   #69
yep, thread closing in 3...2....1...
eTiMaGo is offline
What Kind Of Super Charger Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 3 06-08-2009 05:28 PM
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 07:48 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 03:13 PM
