#19 |
#20 |
Yaris = <3
Drives: '08 Sedan - Flint Mica Join Date: Jan 2009
Nice! I'm very excited to add this in =D I like the idea of the little 4-way switch more than the stalk though. Will look much cleaner =D **stoked**
..:'; Nick ;':.. ============================== 2008 Yaris Sedan - Flint Mica ============================== Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter ============================== |
#21 |
I wonder if it is mechanically limited to the 90 degree positions or if you can accidentally press two switches at the same time with a 45 degree motion?
#22 | |
Yaris = <3
Technical/Catalog Information 500-526 Vendor APEM Components Category Switches Type Navigation Switch, PCB Mount Actuator Type 4-Way Selector Switch Function 2 Axis Output Mechanical Switch Operating Force 100gf Contact Rating @ Voltage 0.05A @ 24VDC Termination Style PC Pin Lead Free Status Lead Free RoHS Status RoHS Compliant Other Names 500 526 500526 679 2289 ND 6792289ND 679-2289
#23 |
I noticed in the PDF that it says actuation at 90 degree positions, which hopefully means that only one can be closed at a time. If more than one could be, then you could be trying to bump it up with the + and accidentally hit off.
#24 |
Yaris = <3
Yeah, that would be counter productive :P
#25 |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
Wow, awesome job on the write-up man. I wish I could have done it, but I'm not that organized :) and flutie98...CTScott put together an LED module (that I still have yet to install...sorry scott) :( But I will get to it soon and do pics and a small write up on it so he can sell em to you guys and you can install them.
My Car Rules! |
#26 |
Learn to Relax
Thank you, Vince87 and CTScott. This is my next project.
#27 |
Yaris = <3
Woot! My clutch switch is in the shop today; picking it up tomorrow. I'll probably do this up on Sunday, as long as I can get the switch and resistors on Sunday.
#28 |
Learn to Relax
I couldn't find the resistors 290 and 340. Are those the correct values? They also had 1/4, 1/2 and 1 watt resistors. Which wattage?
#29 | |
You can use any value within these ranges: 216 to 264 ohms for one between resume and on/off 351 to 426 ohms for the one between set and resume 819 to 1001 ohms for the one between set and cancel For wattage, 1/8 or 1/4 watt is fine. |
#30 | |
Learn to Relax
#31 |
Drives: 2009 YARIS 3DR Join Date: Aug 2009
Just installed the factory cruise parts. I used all new parts from TRDSPARKS, Very easy install. On my 09 3dr. liftback w/manual trans. Yes the icons in the cluster work also!.THANKS to all that provided part #s and insite.
#32 |
![]() Drives: 2007 2DR Yaris Join Date: May 2009
Hey just a quick question for you guys: has anyone done it on a 2006 yaris? I thought it was still the Echo, hence I wrote in the DIY that it was for the 07-08...
#33 |
#34 |
![]() Drives: 2007 Toyota Yaris 2dr Join Date: Sep 2009
Hi, Does anyone have the radio shack resistor part numbers by chance... Would love to try this mod, I just got my 2007 yaris yesterday, and no cruise is a bummer for my 60 mile commute, thanks in advance!
#35 |
![]() Drives: 2007 yaris Join Date: Aug 2009
radioshack usually sells reisitors in packs, not individually. I used a 300 resistor pack (3 or 4$) and just combined the ones I needed to get the appropriate resistance, but this is long and requires a multimeter or reading all teh color codes (even worse). Your best bet is Digikey.
#36 |
If you buy the 500 piece "value pack" for $12.99 you get an assortment that includes 220 ohms, 390 ohms, and 1K ohms.
If you buy them as the 5 packs for $0.99 each, you can get 220 ohms (271-011) and 1K ohms (271-004), but not something in the range of 351 to 426 ohms. Although, You can buy a pack of 150 ohm resistors (271-010) and use one of those in series with one of the 220 ohm ones to get 370 ohms. |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
