Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
sedan cluster should be the same size as the liftback cluster, but the plugs to connect are different from the liftback......
Also.....is your car ABS enabled kustom? If not, you will run into problems like Lewis and I.... :P |
pink wheels are cool
i dont think I have ABS
I think the 08+ USDM cluster works on both i think so i guess its the one way to go at the moment |
Heart Up! Vitz
I have someone on here who is test fitting a 09 w/ ABS cluster on his 07 non-ABS car....I'll let you know whether it works or not..
But: 08 w/ ABS accepted my RS cluster. Scott's 08 w/o ABS didnt accept it His 09 with ABS did... So i highly doubt yours would accept a cluster w/ a tach...speed data won't be sent the same way like it is through the speedometer only cluster~ jus saving you the trouble and money... But go for it, we already have 2 other guinea pigs on here hahaha |
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
R.I.P. Oz Cluster
ok get back to making the tach fit the clock area
Heart Up! Vitz
I hooked it up to my test bench last night and had the same result with making the speedo change but the odo didn't increment. I just need to get to the bottom of the extra bytes in the speed message.
Heart Up! Vitz
Did your 09 send any additional messages from my RS cluster that could help you out with that? I know you said you were going to try that out in my thread...dont know~
My 09 sent the same data to both its own cluster and to your RS cluster. It's entirely possible that the odo increment data is sent in an entirely different message. I have 11 more messages from the 09 data capture to decipher.
Scott - what about starting a new thread keeping us informed on the progress and release of the Yargauge? It seems like the best answer for so many of us who want a tach but within the confines of the existing OEM cluster setup (i.e. not a separate tachometer on the dash and don't want to have to mess with the odometer flashing.
This thread on the OZ cluster is about as dead as a doornail. |
Maybe for you but not for me. I'm hoping Scott can figure out a way to make the Km/L and gear display work.
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
#13 | |
Based on the reverse engineering that I've done so far on the clusters, I believe that we will find that the ECM does the calculations and sends the message up to the cluster. I just need to figure out the message ID and packet structure of that message, as all of the data needed to do the calculation is already available. |
#14 | |
All I can find is you tube videos of it working.... Gear Display works It appears on this one the Km/L works as there is something lit up under the clock I don't think any of these guys are on the forum and from what I understand the Km/L and Gear display works in Europe and I ain't anywhere near Europe.
#15 |
#16 | |
The YarGauge has its own thread that I update. Lewis, If you don't mind I'll attempt to make the necessary modifications to make the OZ cluster visible to the USDM driver. |
#17 | |
#18 |
sorry Tony- my mistake in wording- I just meant that for all the folks looking for a tach in the cluster it was dead- not dead for everyone.
| DIY - Change your Gauge Cluster Color | vodkalush | DIY / Maintenance / Service | 89 | 04-29-2019 09:41 AM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 12:59 PM |
| Shifter knob/gauge cluster color | DevilGirl | Cosmetic Modifications (Exterior/Interior) | 3 | 08-11-2009 10:18 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 11:37 AM |
