Heart Up! Vitz
Drives: トヨタ Vitz Join Date: Jun 2007
My cluster came from a RHD.
Scott, just for clarification, Doing the swapped wiring configuration from what you've explained to me above....will that get my passenger seatbelt & passenger airbag light indicator working? My turn signals work correctly, the light beam indicator in the cluster (different icon than US icon), turns on when i have car's lights on perfectly. Now if I do your wiring swap config. would that mess up things already working properly ie: turn signals, light indicator on cluster showing, etc..? As for the dimming, thank you for the help. I will try that out when the whole flashing of the miles to accurate kilos gets done... P.S. I forgot to mention....E-brake icon stays on in the cluster even though I have the e-brake all the way down LOL.... Techstream update: Toyota dealers said they can't flash my cluster. The mechanic there said himself they dont do it all, comes from factory. They send all there clusters/gauges (that need to be calibrated) out to a company that burns the odometer readings into the clusters for Toyota dealerships.....and then ships back to the dealers. I have to go to this company to get it done...weird right? Will update soon (I'm going either tomorrow or Wednesday)....and if the company is good, and for some reason Lewis's dealership doesnt do it, I will work w/ Lewis to get it done through this company... Company URL: http://www.paspeedo.com/ |
#2 | |
Hmmm. So, beam, and turn signals work. How about the headlight indicator and the check engine light? If the headlight indicator doesn't work, I would do the 9 and 16 swap. The 2 and 7 swap should fix the brake light issue. |
| DIY - Change your Gauge Cluster Color | vodkalush | DIY / Maintenance / Service | 89 | 04-29-2019 10:41 AM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 01:59 PM |
| Shifter knob/gauge cluster color | DevilGirl | Cosmetic Modifications (Exterior/Interior) | 3 | 08-11-2009 11:18 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 11:05 PM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 12:37 PM |
