Old 12-06-2006, 12:32 PM   #829
I agree about the low fuel thing, kinda experienced it myself (i think)
When I had upgrades done to the car, the guys at the workshop left the engine running most of the time, and it actually ran completely dry.
Once it was refueled, and the car back on the road, I found I had crappy mileage too, half a tank only lasted about 150km.
Then, a couple of days later, I was on the highway, pedal to the metal in 5th, when the air/fuel sensor meter I installed pegged the needle on very rich, and the warning buzzer went crazy for a little while. Then, the meter went back to normal, and so far, normal mileage seems to have returned.
I'll be sure to refuel before the gauge shows two bars from now on
Old 12-06-2006, 01:43 PM   #830
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
Alright I have a US Yaris HB... I have 2 bars left and I want to find out what my MPG was... What equation should I use? How many Gallons of gas fit in that tank? Do I just refill the tank and minus that number from the size of the tank then divide that by the amount of miles I have done? There are too many numbers here with the Metric/IMP/ US conversions…I’m slow and need to be explained things slowly!
Nutzoids is offline   Reply With Quote
Old 12-06-2006, 01:53 PM   #831
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
100% highway at 3000rpm (70mi/h)
39mpg
100% stop&go city, moderate driving, cold weather+snow
26mpg (35 miles on a bar)
that's for a 4000km on clock, 5 speed Hb with original oil/filter
Just changed oil to synthetic & waiting to see if ther's any change in mpg
hystria is offline   Reply With Quote
Old 12-06-2006, 02:35 PM   #832
BMGYaris
Drives: Yaris 3dr Hatchback
32mpg (35 miles on a bar)
What do you mean by on a bar?
BMGYaris is offline   Reply With Quote
Old 12-06-2006, 04:36 PM   #833
hystria
hystria's Avatar
fuel level bar. of course, this is just a first approximation of my city mileage as I just moved into the city. i'll be back few tanks later for a more precise mileage
Old 12-06-2006, 05:16 PM   #834
boris13
Drives: 2007 Yaris Liftback, 5-speed
And are you using Imperial gallons or US gallons?
boris13 is offline   Reply With Quote
Old 12-06-2006, 06:21 PM   #835
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
nutzoids: just fill the tank, note how much fuel was put into the tank and how much distance was travelled by noting on the odomoter,
i have a little pad i keep in the car and once the car is filled, i write down both numbers and do the math at home.
divide the distance travelled by the amount of fuel used.
it's good to average this over a number of tank fills to get a better idea of fuel economy.
stuffy is offline   Reply With Quote
Old 12-06-2006, 08:01 PM   #836
hystria
hystria's Avatar
your right! topic edited
Old 12-07-2006, 09:10 PM   #837
Typer73
Tired of the Stars!
Typer73's Avatar
Drives: '07 Meteorite LB
Nutzoids-- I also have a US LB (averages 33 mpg). I always zero out my Trip A gauge when I fill up, saves me from having to do too much math.
I get a receipt that shows gallons used and write down the mileage from Trip A on it with the pen kept in the "handy-dandy driver's side glove box", then zero it out for the next fill-up. Do the dividing math at home with a calculator!
Typer73 is offline   Reply With Quote
Old 12-07-2006, 11:16 PM   #838
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Q. What do I do when I just want to do a partial fill, like, say, throwing $5 worth into it?
A. DO NOT zero your trip odometer. Save your reciept(s) and when you finally DO fill it up, record your total miles from the trip odo and zero it. Add-up your total gallons from your reciepts. Divide the total miles by the total gallons. There you go, as accurate as anything, no estimating.
btw, I'm still getting 36 mpg avg., and it's pretty consistant, like my graph posted on 10-2 shows.
Racer X-8 is offline   Reply With Quote
Old 12-09-2006, 03:24 AM   #839
swng
swng's Avatar
Drives: 06 3-dr auto RS
My latest tank:
Fuel Cost
$38.28
Distance travelled
516.2 km
320.77 miles
Fuel Amount
39.71 litres
10.49 US gallons
8.73 Imperial gallons
Cost of Fuel
$0.96 per litre
$3.65 per US gallon
$4.38 per Imperial gallon
Fuel Economy
7.69 litres per 100 km
30.58 miles per US gallon
36.73 miles per Imperial gallon
Mileage Costs
7.4157 ¢ents per km
11.93 ¢ents per mile
NB: Canadian currency used.
Winter and traffic jams have hurt my fuel economy.
For calculation method(s), I use the methods described here:
https://www.fueleconomy.gov/mpg/MPG.do?action=calcMPG
For the actual calculations, I use the free calculator here:
http://oee.nrcan.gc.ca/transportatio...ut.cfm?attr=16
swng is offline   Reply With Quote
Old 12-09-2006, 07:41 AM   #840
wibrian
wibrian's Avatar
Drives: Red LB
1st tank 32.6 mpg, 2nd 35.4 Hope it keeps going up
May your heart be true when darkness falls.
wibrian is offline   Reply With Quote
Old 12-09-2006, 07:43 PM   #841
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I can't emphasize how much slowing down can help your gas mileage. For gas mileage purposes, there is no reason to go over the speed limit. Add that to accelerating slowly, and doing everything possible not to use the breaks, and being really patient all the time. Even going 80 mph for a few miles can drop the gas mileage significantly on a tank of gas that was otherwise averaging 55 mph. It all comes down to how much gas you want to save against how slow you feel comfortable driving. The Pulse and glide method works as well, but you usually don't want to go to much lower than the speed limit, so its use is limited on public roads.
Everything matters when it comes to gas mileage. Weather, Tire air pressure, weight in the car, if you let the car warm up, how much you let the car rev before shifting, any accessories you use in the car, how hilly or flat your usual driving spots are, stopping in traffic, braking a lot, etc.
BTW, I ran my tank completely dry once by mistake, and it did not seem to hurt my fuel economy at all.
Having a tach really helps with gas mileage. Knowing when you shift and how much you are really accelerating can help you go slower and save gas.
Colin Chapman disciple
Old 12-09-2006, 11:39 PM   #842
mutatio
Drives: Flint Mica AT Sedan
I thought you folks might enjoy the opportunity to bolster the numbers for the yaris.
http://www.fueleconomy.gov/mpg/MPG.d...ta&model=Yaris
Register, and you can add yours to the mix. :)
mutatio is offline   Reply With Quote
Old 12-15-2006, 12:43 AM   #843
Whoohoo 19.1MPG - 12L/100km
Warming up the engine properly, short trips and being stuck 2 and a half hours in a traffic jam certainly don't help... Gotta love this city
Can't wait for my road trip for the holidays... that should give us better numbers!
Old 12-15-2006, 02:10 AM   #844
swng
swng's Avatar
I know how you feel. I encountered a serious traffic jam this afternoon. It is going to hurt the result of this tank.
Can't wait to know about how your car performs in your road trip. Bon voyage!
Old 12-15-2006, 02:38 AM   #845
2 and half hours in a traffic jam not only hurts your mileage, but with race seats, it hurts your butt BAD! Once I got home I didn't want to sit down for an hour or so
Old 12-15-2006, 11:01 AM   #846
DorytheYaris
aka Eleni
DorytheYaris's Avatar
Drives: 10 Yaris LB Auto- Blazing Blue
Originally Posted by hhcchen View Post
i hope that's the unbroken in mpg...
anyone broken in there yaris yet...???
anyone with 1000+ mile/1600+ km yaris yet...???
2,200 miles here. I bought it on November 6 with 8 miles on it.
My boyfriend and I drive my Yaris all the time rather than his 2006 Honda Civic coupe!
DorytheYaris is offline   Reply With Quote
