Old 11-08-2009, 10:17 AM   #1
sex
sex's Avatar
Drives: 09 5DR
DIY - Standing rear wiper for hatchback
Story:
The rear wiper is a shelf for dirt. During the winter months, I suspect it'll clear snow more effectively by pushing it down instead of bunching it to the side. This took about 30 minutes and is easily reversible.
Tools:
1. 10mm socket - used on wiper arm and motor
2. #2 Phillips screwdriver - used on motor
3. Slotted screwdriver with tape - used to pry trim panel
Procedure:
1. Remove rear wiper arm (refer to service manual pg WW-29).
2. Pop off the back door trim (refer to service manual pg ED-142).
3. Disconnect the white power plug from the wiper motor.
4. Remove the three bolts holding the motor.
5. Remove the four screws off the cover plate.
6. Lift the long arm off the white gear.
7. Rotate the short arm to the left and reconnect the long arm.
8. Reassemble and enjoy.
sex is offline   Reply With Quote
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
How-To: Liftback Rear Wiper Arm - Full Pivot! Chris07LB DIY / Maintenance / Service 5 07-24-2009 03:08 PM
Rear wiper: EZ mod so it pulls back all the way joelitton Cosmetic Modifications (Exterior/Interior) 10 10-22-2008 10:30 AM
Rear wiper function, is this normal? Yaris Dick General Yaris / Vitz Discussion 7 11-08-2006 09:46 AM
