Old 01-04-2010, 06:03 AM   #11
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Originally Posted by fmicle View Post
I started hearing the clunking sounds ever since I installed the new springs (Progress, 1.4" drop) and shocks (Tokico blues). I shortened the bump stops by about half an inch in the back and about 1 inch in the front. Right after the install I took it for a ride and heard the clunks while going over the driveway curb. I thought the coils needed to set in. After that, nothing for more than a month. Then I had 2 adults in the car, one in the front, one in the back and heard the same sounds again a few times. I checked under the car and couldn't see anything bad, no rubbing, no scratching. I don't see how the sway bar could hit anything, since mine (Ultra Racing) is installed right under the axle...
I believe the clunking comes from the fact that my Progress coils are different than the stock ones, the first 3 spirals sit on top of each other so there is more contact between the coils thus, more potential for clunking noise...
I'll say put it back to the original position (lower pivot point and then problem solved) I put it back on mine and it "comfort' level is back & there is no longer any strange sound fro the rear.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
